Which soldering torch....
French_guy
Michigan
Hello
I'm not a professional plumber, but may have to do occasional copper/copper and copper/brass sweating
Which of the torches available at Home Depot (Bernzomatic) would you recommend?
For copper to brass, do I need MAP ?
I was looking at the TS4000 (propane/Map) or TS3000 (propane only)
Thanks
My Bernzomatic from early on is very intermittent lighting. I bought a Worthington LT91, and it is first time every time so far.
The LT91 is undersized for much copper sweating, but I expect a similar model with a bigger burner head would do that very well.
Montreal, Canada
DIY should not use Mapp gas, you can burn the copper within seconds. The copper turns powdery red, evaporates the flux, and the solder beads off it.
DIY *should* get a Trigger Start Torch Head, it is much safer, and let's you keep constant heat during sweat jobs as you re-ignite faster from flame blow-outs.
Once you use Trigger Start's you'll never go back to legacy flint lighters.
Montreal, Canada
Sweating does not require a lot of skill and a DIY can do a good job, but you MUST practice.
Get an extra length of copper pipe and a handful of fittings, it'll cost about $10, and let you practice sweating at least a dozen times before you get it right.
You don't want the permanent final sweating for your home to be the "practice one".
Stuff
Pennsylvania
More expensive but I was recommended the TurboTorch STK-99 a couple years ago. It does the job for basic propane copper sweating.
French_guy
Michigan
Here is my very first attempt (with the copper cap)
The second attempt is with the brass PEX fitting
Does it look good? Something I'm doing wrong?
Montreal, Canada
I promise it'll look better after you do it 20 times, it'll be worth the $5 in copper parts.
If you think you've become an expert on the 2nd attempt, then go ahead and close up the drywall and tile and let that put you to sleep at night.
Three look good to me, and IMG_1479.JPG may be good also.
