Which shower arm adaptor
Discussion in 'Shower & Bathtub Forum & Blog' started by md001, May 18, 2010.
  1. md001
    md001 New Member
    May 18, 2010
    new jersey
    Anyone know how to tell what kind of ball end shower arm you have, in order to determine which adaptor to purchase to turn it into a regular threaded arm? There seem to be at least three of four different adaptor (american standard, gerber, etc.) Perhaps someone knows the diameter of the threaded piece behind the ball joint for the various makes? I'd take the shower head into a store and just compare it to the adaptors, but it seems like not many places actually keep the adaptors in stock. Any help appreciated.
  2. hj
    If the ball is integral to the shower arm, it was proprietary, possibly PricePfister, but ANY adapter is going to create a very "wiggly" connection which will be unsatisfactory for most users. Replace the shower arm with a threaded one.
  4. jimbo
    jimbo Plumber
    The two that I ran into a lot were AmStd and PP. They were about the same diameter, but different thread. You just had to know which you had. The shower arm was made (usually) by the brand who made the shower valve.
    Those adapters are getting scarce, and I don't know any good reason not to just replace the arm.
  5. md001
    md001 New Member
    May 18, 2010
    new jersey
    Thanks for the comments - that's kind of what I was afraid of. Is changing the shower arm difficult? I.e., do I need to remove tile to do that, or should it just unscrew? I half-heartedly tried to turn it with channel grips and it didn't move (counter clockwise) - I didn't try to hard though, nervous that I can't actually see what I'm trying to twist.
  6. hj
    IF it were to break, and it DOES happen, then it was already cracked and just waiting for an opportunity to break in the wall and give you a flood. Otherwise unscrew it. If it turned EASILY when you tried with the Channelocks, that would have meant it was TOO loose and also probably leaking in the wall.
  7. md001
    md001 New Member
    May 18, 2010
    new jersey
    Okay, I'll give it a shot. How critical is it to shut off the water supply before taking the arm off?
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The water is shut off at the mixer so just unscrew it.
    I would not turn on the mixer while it is removed though...
  9. hj
    You do NOT have to shut anything off other than the shower valve, and that should already be off unless you are bathing at the time.
Similar Threads: shower adaptor
Shower & Bathtub Forum & Blog Help with adaptor for old 1960s ball end shower arm Jul 28, 2012
Shower & Bathtub Forum & Blog Kohler shower caukless adaptor tricks? Mar 10, 2012
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Today at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Yesterday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Tuesday at 6:47 AM
