Which pipe for sewer line
Discussion in 'Canadian Plumbing Code Questions' started by diganddig, May 9, 2012.
  1. diganddig
    diganddig New Member
    Apr 27, 2012
    Calgary Alberta Canada
    Hello
    I'm in Calgary Alberta. I need to replace my sewer from the house out to the City service - around 8' deep. Should I use 4" ABS-DWV Schedule 40 Cell Core pipe? Or should I be using 4" PVC Solid Wall DR 35? Or something else?
    Thanks
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    What do they use in your area for new construction? Cast iron or solid core PVC is common here.
  4. hj
    It depends on what is "used" in your area. Here, it would be almost exclusively ABS pipe and fittings. Other areas use PVC, and still others may have a 50/50 mix depending on the plumber's preference.
  5. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    we use DR35 PVC sewer pipe for the main
  6. Willie Two
    Willie Two New Member
    Jan 1, 2011
    British Columbia
    Why do we Canadians use PVC Sch 35 vs ABS Sch 40 pipe. Is it cost ? Material flexibilty / frost or is it just better ?
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Willie, I don't know that it is a "Canadian thing" at all. The choice of materials will vary from place to place here in the States too. Some areas don't stock ABS at all, other places use ABS 100%. Go figure.
Similar Threads: pipe sewer
Canadian Plumbing Code Questions sewer drain pipe installation Sep 28, 2012
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Vent pipe size - Alberta Jan 9, 2015
Canadian Plumbing Code Questions water pipes below electrical panel Oct 6, 2014
Canadian Plumbing Code Questions Use of Copper Potable Water Pipe Underground Apr 29, 2014
