Which is better ?Wax Toilet Rings vs Wax-free Toilet Rings
Discussion in 'Toilet Forum discussions' started by herbolaryo, May 31, 2007.
  1. herbolaryo
    herbolaryo New Member
    May 26, 2007
    San Francisco
    I have seen the wax toilet rings and the wax-free toilet rings in the hardware store.
    1. What are the pros & cons of wax-free vs wax toilet rings?:confused:
    2. Which one is easier to install?:confused:
    3. Which one last longer?:confused:
    4. Which one does not leak easily?:confused:
  2. jadnashua
    EIther should last a long time. Wax, probably longer. If your toilet is not shimmed properly so it doesn't rock, a waxless migth keep it from leaking. A waxless is more forgiving on the depth of the flange (i.e., one where the floor has been built up around it) since it has a built-in horn. The waxless rely on rubber which is pretty reliable (often neoprene or other synthetic), could break down in certain circumstances (but it should be a long time). Wax works, is cheaper, but can slip and is messy. If you have reason to want to remove and replace the toilet, the waxless is quicker, since you don't have to scrape off the old one prior to installation of a new one. This is particularly handy during remodeling when you might need to set and remove the toilet a few times as you progress in the remodeling.
    [​IMG]
Similar Threads: better Toilet
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Better solution for tank bolt leaks for Toto toilet? Nov 16, 2010
Toilet Forum discussions Will a 10" Rough-in Toilet be better then a 14"? Possible fixes?? Jul 7, 2010
Toilet Forum discussions Better Life Styles Inc, toilets that are vented May 4, 2010
Toilet Forum discussions 2008 Champion4 Toilet--any better? Feb 20, 2008
