Which Gas Hot Water Heater?
Discussion in 'Water Heater Forum, Tanks' started by walds11, Dec 6, 2009.
  1. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'd go with a Bradford White.
    The FVIR is far superior to the others in reliability design...
  2. The Rich Dude
    The Rich Dude New Member
    Feb 4, 2010
    Vancouver, BC
    whats a FVIR? Thanks
  3. Redwood
    Dec 15, 2007
    Service Plumber
    Flammable Vapor Ignition Resistance...
    Essentially it offers protection if you were to spill a flammable liquid near the water heater the vapors could be ignited by the pilot light or, burner causing a fire to occur. FVIR has a flame arrestor which will prevent flashback and sensors which detect a flammable vapor event which shut the unit down. This protection is now required by federal law on gas water heaters.
    The problem is the flame arrestor has a tendency to become clogged with dust and lint that causes a lack of combustion air and a taller flame which triggers the flammable vapor event sensor. Some FVIR water heaters have the air inlet on the bottom of the unit and a flame arrestor with a small surface area which has proven to be problematic especially for the American Water Heaters initial design of its Flame Guard and Flame Lock where they used a non-resettable thermal fuse in the thermocouple resulting in a class action and burner redesign. See the famous Whirlpool Thread Here Or, here is some more good info http://411plumb.com/troubleshooting-flame-guard-flame-lock-water-heaters
    Once you get past the FVIR units that are designed like vacuum cleaners and into the ones that have the air inlet on the side near the base of the unit instead of the bottom you are essentially left with Rheem and Bradford White. Rheem has the smaller air inlet of the two and is not resettable. Leaving Bradford White as the best IMHO... http://411plumb.com/bradford-white-defender-water-heater-review
  4. dargo
    dargo New Member
    Jan 9, 2010
    MA
    I still do not get the FVIR air inlet on the bottom. Again, as most posts in my past state, I have had a AO smith water tank. No issue and had another one installed. So far in 7 month the screen looks new...I will take a pix. I do not get it since I would love to know how the screens get dirty...
  5. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    It is also possible that the T&P valve on your old heater was stuck shut and could have ended in a very serious problem at some point. Now that you have a new one the new one is working as it should and a thermal expansion problem was found.
Similar Threads: Water Heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
