Which coupling for 3" PVC to 4" Cast Iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by takelargebites, Dec 15, 2011.
  1. takelargebites
    takelargebites New Member
    Sep 7, 2011
    NC
    I need to connect my new 3" PVC drain line to the old 4" cast iron drain. The pipes are on the horizontal in the basement. Which Fernco coupling would be preferred? The 1056-43 Flexible coupling or the ProFlex 3000-43 ? It looks like either coupling would accomplish the same thing but it seams like the ProFlex would be more resistant to shear since it's banded.
  2. hj
    You are correct, especially since the "Fernco" cannot be used for that application.
  4. Terry
    Aug 17, 2004
    Above ground is when you need a shielded coupling; required by code.
    Plumbers always use shielded couplings.
    There are times in the ground, when you can use a non-shield coupling, since the ground is supporting.
    When you join pipes, it's important to measure the OD of the pipe.
    A new 4" cast iron pipe would be 4-3/8" OD
    An old 4" cast iron pipe can be as small as 4-1/8", which is considered a copper pipe size.
    If I have copper pipe size cast, then I use a mission copper coupling x no-hub. Which does work with PVC if it's standard waste sizing.
    [​IMG]
  5. hj
    quote; I generally only use banded ones myself, but thought they were only required underground.
    That is the ONLY place they are NOT required, but usually outside the building.
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    In Illinois shielded couplings are required underground. And above ground we are allowed to use no-hub couplings but must use a no-hub transition adapter on the PVC and or ABS pipe.
  7. hj
    When I was in Chicago, we never used PVC, ABS, OR No-Hub cast iron.
  8. takelargebites
    Sep 7, 2011
    NC
    My cast iron measures 4-1/4" OD. Does it sound like a Mission CP 43 (4" CI to 3" PL, ST, or XH CI ) would be the way to go? I'll see what the supply house has tomorrow morning and then track down an inspector to get his ok too.
  9. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I did not say Chicago, said Illinois. When I work in Chicago, we do not use PVC, ABS or no-hub. Still lead and oakem.
Similar Threads: coupling Cast
Plumbing Forum, Professional & DIY Advice Is there a fitting - from 4" cast iron to the coupling (fat part) of PVC fitting? Jul 26, 2015
Plumbing Forum, Professional & DIY Advice Preventing corrosion with no-hub couplings on cast iron Feb 28, 2013
Plumbing Forum, Professional & DIY Advice Cast iron no hub couplings show leakage... why? Jun 22, 2012
Plumbing Forum, Professional & DIY Advice 3" Mission No Hub Coupling Appropriate? Thursday at 12:53 PM
Plumbing Forum, Professional & DIY Advice PVC Male - Brass Female Coupling Oct 17, 2015
