Which Cast Iron Flange Replacement is best
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tomtbone, Jul 16, 2010.
  1. tomtbone
    tomtbone New Member
    Feb 11, 2010
    tomtbone in Boston
    Today I successfully removed the old cast iron toilet flange and am left with a 4" cast iron pipe. The top of the pipe will be about 1.25" below the level of the finished floor. I am looking at a couple of PVC/ABS replacement flange from Oatey and Sioux Chief. Which one would you guys reccomend?
    Oatey Compression joint with screws to tighten compression
    [​IMG]
    Oatey Twist 'n' Set
    [​IMG]
    Sioux Chief Gasketed Closet Flange
    [​IMG]
    Sioux Chief Push-Tite Flange
    [​IMG]
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    They are all about the same but I like the ones with a stainless steel ring.
  4. tomtbone
    tomtbone New Member
    Feb 11, 2010
    tomtbone in Boston
    Also, PVC or abs
  5. jadnashua
    ABS vs PVC is irrelevant when attaching to CI, so pick the one you can get easily, or is less expensive. I'd definately go for one with the (stronger) SS ring, though. Won't rust, or deflect or break as easily as an all plastic one.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    THIS IS WHAT YOU NEED THOSE CHEAP PLASTIC FLANGES ARE JUST THAT CHEAP !
    THEY ARE MADE AS REPLACEMENT FOR BAD PLASTIC FLANGES !
    YOU NEED TO GO TO FRANK PATTERN & MANUFACTURING WEB SITE THEY HAVE ONE THAT IS 4" X 4"
    TO BRING YOUR REPLACEMENT UP ABOVE THE FINISHED FLOOR LEVEL WHERE IT NEEDS TO BE
    http://www.instantset.com/closet_rings.htm
    Home
    Announcements
    Product Catalog
    Closet Rings
    Cast Iron
    Model Numbers
    Size
    Regular
    3"x2"
    30
    4"x2"
    40
    4"x2"
    40TC
    (w/test cap)
    Instant Set® - Closet Ring 4"x4"
    Model Numbers
    Size
    Regular
    Deep
    4"x4"
    44
    Instant Set® - Closet Ring 4"x6"
    Model Numbers
    Size
    Regular
    Deep
    4"x6"
  7. tomtbone
    tomtbone New Member
    Feb 11, 2010
    tomtbone in Boston
    So do those flanges fasten to the outside of the pipe then? I'm not quite getting how they work. Also, for the 2" deep size, how much pipe does there need to be to grab onto?
  8. tomtbone
    tomtbone New Member
    Feb 11, 2010
    tomtbone in Boston
  9. hj
    Any compression flange will ONLY seal if you can get the pipe smooth enough. I ONLY install cast iron flanges on cast iron pipes.
  10. tomtbone
    tomtbone New Member
    Feb 11, 2010
    tomtbone in Boston
    I understand that yes. What do you do though if the cast iron pipe is more than an inch below the finished floor level? Are those blue cast iron compression flanges adjustable?
    I also saw at Lowe's today that Oakey is making a cast Iron Twist and seal flange
  11. MASTERPLUMB777
    Aug 6, 2007
    Texas
    The blue cast iron instant set tightens on the outside of the pipe by tighting the 3 7/16 bolts
    around the flange, !
    That is why you get one that is 4" deep it sets down below the floor and extends up to
    above flooring to make the correct fit !
  12. MASTERPLUMB777
    Aug 6, 2007
    Texas
    If i was doing it i would take both 4x2 and 4x4 to dry fit and make sure it tightens
    correctly and will work properly ! !
    Then return the one i don"t use !
  13. jadnashua
    I think what HJ was alluding to was that he only installs a new leaded ci flange on a ci pipe...they come with different depth throats to accommodate the height of the ci riser. This is the longest lasting, strongest connection, least likely to leak of all of the choices.
Similar Threads: Cast Iron
Plumbing Forum, Professional & DIY Advice Hard buildup in cast iron drain pipe Mar 18, 2017
Plumbing Forum, Professional & DIY Advice How do I tell if the Soil Pipe is Cast Iron or Steel? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice PVC to Cast Iron for toilet drain Mar 12, 2017
Plumbing Forum, Professional & DIY Advice Chinese cast iron no hub vs Charlotte Mar 11, 2017
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Feb 21, 2017
