Whether to caulk and scribe my vanity
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buttonsrtoys, Dec 27, 2012.
  1. Buttonsrtoys
    Buttonsrtoys New Member
    Nov 1, 2012
    Nova Scotia, Canada
    I'm finishing up an install of the vanity in the pic. The vanity cabinet and sink are fastened to the wall with lags in blocking and anchor bolts in plaster so it seems quite secure. I made sure the sink was level, but after the install I noticed that the floor isn't level, so the front of the vanity is 3/16" off the floor and the back sits on the floor. It's not enough to notice so I'm thinking of leaving it. I could take it off and scribe it, but its melamine and finished on the bottom, so ripping it and setting it on the floor seems like it would wick up lots of water and break apart.
    I'm curious for feedback if leaving it is the way to go. Alternatively, I could run a bead of silicone under it. If I go this route, should it be clear or white?
    Also, the sink top is rounded where it butts against the wall. Should that get a bead as well? White?
    Thanks in advance...
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Caulk both, white
  4. jadnashua
    Put some shims underneath the front before you caulk it (done right, the caulk would hide them). Otherwise, when/if someone leans on the thing, you won't be stressing the cabinet. It is designed to be sitting on the floor all around - you don't want it just hanging there from the back edge.
  5. hj
    Or put a white base shoe around the bottom of the cabinet.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Yes you need to caulk around the back of the sink to prevent water splash from running
    down between the sink and wall it calls for a water proof washable surface
    ie; water proof caulking
Similar Threads: Whether caulk
Plumbing Forum, Professional & DIY Advice Advice on whether toilet drain will work with close 180deg turn Mar 25, 2014
Plumbing Forum, Professional & DIY Advice Back-to-back toilets -- how do I know whether I have cross or Y fitting? Jun 12, 2013
Plumbing Forum, Professional & DIY Advice Question about whether to use teflon tape on toilet input valve Mar 25, 2010
Plumbing Forum, Professional & DIY Advice Is it necessary to add cleanouts? Also whether to tie in A/C condenser? Oct 1, 2007
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
