where to solder copper pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by richb2, Sep 13, 2006.
  1. richb2
    richb2 New Member
    Feb 12, 2006
    New York
    This is a simple minded question, but I am a simple guy. I am putting in hydroponic underfloor heating. I finished running the PEX and now I need to run 3/4" copper tubing back to the boilder room, before I call in the plumber to hook the baby up to the furnace. It is about a 25 foot run. The basement ceiling is a cheapo drop down with removeable panels, and no more than 6 inches of space below the joists. Do I build and solder the copper tubes on the floor, and then try to get the long tubes into the ceiling? Or do I mount the tubes with hangers in the ceiling first, and then solder them in place? I have a propane torch and I am afraid of igniting the place.
  2. ToolsRMe
    ToolsRMe New Member
    Mar 12, 2006
    CO
    Solder in place. It's much easier.
    Make sure you have
    a) A water sprayer bottle. I pre-spray with water on the wood, etc.
    b) A cloth heat shield (around $20) if your joint is, say, less than four inches from combustible material. Putting the cloth in back is fairly cheap insurance.
    c) A fire extinguisher nearby.
    Once you finish sweating the joint, spray the area with water in case there are embers.
    Yes, this is overkill in terms of safety but it's cheap insurance; and it's your house.
  4. prashster
    prashster New Member
    Dec 7, 2005
    respectfully disagree
    Unless you're a good solderer (is that a word?!) I'd do as much of it on the ground as possible. I wouldn't do the WHOLE thing on the ground bkz it'd be tough to measure exactly and lift it. But I'd do it in strategic pieces that minimize the amount of overhead soldering you have to do.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Why don't you run the PEX back and save on heat loss through the copper and the added cost?
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Are you useing hydroponic heating to add humidity in the air during the winter months? :) :D :)
  7. hj
    heat
    No, to grow grass on the floor for playing games.
  8. prashster
    Dec 7, 2005
    No, to grow 'grass' - the 5-leafed kind.
Similar Threads: where solder
Plumbing Forum, Professional & DIY Advice Solder Ball Valves(3) Confused about Open/Close and Where to Heat? Jan 24, 2011
Plumbing Forum, Professional & DIY Advice Where to drain water (condensation from HRV) Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Where can I tie a 4" branch sewer line in my front yard? Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Tub Drain Leak - Where to repair Jan 9, 2017
