I'm planning to put in a heat recovery ventilator (HRV) that will generate a little bit of water from condensation. That water needs to be drained somewhere.
Can I just put in a drain anywhere I want?
I have existing pipes running through a basement closet I'd like to install the HRV in. So I'd like to just tap into that line, but I'm not sure how: do I just put a full floor drain in mid-air (I assume you'd use a sani-tee to tap into the line), or is there a better way?
The picture below shows more or less what my house is like. The red line is where the condensate drain would be (?). It's just like 1/4 inch vinyl tubing I believe.
Thanks for any ideas.
