Where to buy water meter box?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tsutomua, Dec 26, 2006.
  1. tsutomua
    tsutomua New Member
    Dec 26, 2006
    I am looking for a water meter box or the cover for the box only. I haven't been able to find a store that sells it. Any suggestion would be appreciated!
    Thanks,
    Tom
  2. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Any plumbing wholesaler or building supply wherehouse should have them.
  4. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I've seen them at Lowe's... the box stores carry things like that.
  5. Rancher
    Rancher Guest
    If you're thinking of the concrete water meter boxes and metal (diamond tread) lids... probably the same companies in your area that provide Septic tanks. What the Lowe's and H-depots sell are plastic valve boxes.
    Rancher
  6. Randyj
    Nov 25, 2006
    Alabama
    Those plastic valve boxes are exactly what the local water folks installed when I recently connected to the water system. I don't see many of those old concrete boxes in new installations anymore. Even the big high dollar gated communities are using them.
  7. hj
    box
    HD, Lowes, and most lawn irrigation companies sell the plastic box which is not used almost universally.
  8. jimbo
    jimbo Plumber
    Around here, there is a specialty brick and block company that has the concrete boxes with concrete lid. Commercial suppliers like Apex and Ford supply may also have them.
  9. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Look on line at www.usabluebook.com
    Stock numbers you can look up on the web site are 62042, 62041, 62034, 62035, 62047, 62048, 62049, 62050, 62051, and 63031. One of them may match yours.
    When it comes up in the search, click on the hyperlink and it will show you the detail.
    If you click on the Catalog page at the first link, you will get the page with all of them at once.
    They will charge to credit card and ship same day if you order by 5PM Central time.
  10. tsutomua
    tsutomua New Member
    Dec 26, 2006
    Thanks EVERYONE! I was little surprised to see the many responses in one day. Thanks a lot.
    My water meter is located about 2 feet below the lawn. What I am trying to do is to stack concrete blocks (the gray one, about $1 each) and put the water meter box or the lid only on the top. I am going to apply morter between the concrete blocks. Does anyone foresee problems in this approach?
  11. srdenny
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    They make stackable meter boxes. Concrete blocks may not be the large enough for future meter maintenance. From my experience, when I bury something so that I can't get to it later, my good friend Murphy sees to it that I'll need to. :(
  12. Bob NH
    Oct 20, 2005
    New Hampshire
    What you want is more like a manhole. You should use something at least as large as the 16" square chimney blocks that give you at least a 12" inside square. Think of having to work inside with a wrench to replace the meter.
    The ones at USA Bluebook (my previous post) have complete boxes as well as covers. You may want to put the whole box above the concrete.
    Does someone have to remove the cover to read the meter?
    You might consider leaving the last one without mortar so it can be removed for easier access if necessary.
    You presumably don't live in an area where frost goes down 4 ft.
  13. Randyj
    Nov 25, 2006
    Alabama
    My country bumpkin/trailer trash approach has worked for me quite well.. dig out the hole, take a 5 gal bucket and cut a slot out of the bottom to go around the pipe and meter...or just cut out the whole bottom..insert in hole then go to box store or walmart and buy a round stepping stone from the garden department to use for a cover. If you want to pour concrete around the bucket using it for a form then that's peachy king too.
  14. tsutomua
    tsutomua New Member
    Dec 26, 2006
    Thanks all. I was able to find what I need.
Similar Threads: Where water
Plumbing Forum, Professional & DIY Advice Where to drain water (condensation from HRV) Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Where to run water lines to install washer/dryer in garage Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Where is water in ceiling come from?? Need HELP ASAP May 27, 2016
Plumbing Forum, Professional & DIY Advice Where to Install Water Filter? Jan 27, 2016
