where to buy PE pipe for mainline replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tikicarver, Oct 3, 2012.
  1. tikicarver
    tikicarver New Member
    Feb 1, 2010
    Tehachapi, CA
    I need to replace a leaking main water supply line. The current line would a big expensive job to replace. Got a quote of approximately $3000 for a trenchless replacement job.
    The guy did mention that I could save a lot of money if I ran a new line in put it in myself, then just pay a plumber with the right tools to hook it up.
    He recommended using PE pipe.
    Anyone know where I can buy 1" PE pipe online? I live in a small town and the nearest Home Depot does not carry it.
    Also, are their DIY fittings I can use or do I need to have a plumber install fusion fittings.
    thanks
  2. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    then dont go trenchless, you gonna dig 4 to 6ft down, and however long your front yard is. if not get hone depot to bring it in.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Your Home Depot doesn't carry PE ? Are you sure? It's the black plastic stuff that comes in rolls. Try aisle 5 right next to the water pumps and tanks
  5. tikicarver
    Feb 1, 2010
    Tehachapi, CA
    Didn't see it last time I was there. I'll check again.
    (it wouldn't surprise me since I'm told our HD is the smallest in the country)
    There is a Lowes about an hr drive away, do they carry it?
    Also, is 1" the right size to use?
    Currently I see 1" coming off the water meter and 1" going into the house, but in between is 1 1/4" PVC.
    I'm thinking since there is 1" on either side of the PVC, it doesn't need to be 1 1/4'.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    Yea, 1" is what you need. Lowe's has it also. comes in 100 and 300 foot rolls
  7. tikicarver
    Feb 1, 2010
    Tehachapi, CA
    any recommendation on what type fittings to use? ie Are there any types I should stay away from?
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    I only use brass or stainless steel insert fittings with two opposing clamps. You will have to adapt using an insert x male fitting once you are inside the foundation. Adapt to copper, pex or cpvc. stay away from plastic or nylon fittings. They leak.
  9. hj
    Your 1" PE pipe will be approximately the same size as 3/4" copper, so you might want to increase to 1 1/4" to stay at the same size you have now.
  10. tikicarver
    Feb 1, 2010
    Tehachapi, CA
    Thanks for the info.
    I stopped by my local Home Depot, they don't have PE pipe except for some small diameter stuff.
    They do have 1" white PEX.
    I read on another forum that you can use PEX for a main water supply line but it has to be sleeved.
    If given the choice would you use PEX or PE for a main water supply line.
  11. Tom Sawyer
    Nov 29, 2010
    Maine
    160lb. 1" PE has an inside diameter of 1.062 while 3/4" type L copper has an inside diameter of .0758 The difference isn .309 which is more than 1/4" We use 1" PE for probably 90% of all deeep well pump installations, including the run from the pump to the house. You can run PEX and you do have to sleeve it and it is more expensive. Can you get Home Depot to order you a roll of PE?
  12. tikicarver
    Feb 1, 2010
    Tehachapi, CA
    So local Home Depot doesn't have it and the guy didn't even know what I was talking about. I checked with Lowes, they have it on their website, but I checked 3 local stores and
    none of them carry it and they didn't know what i was talking about. Even checked two plumbing supply stores, they don't carry it. One in Burbank and the other in Bakersfield, CA.
    Finally found a wholesale guy in Bakersfield that has it but his min is 500ft roll.
    I'm beginning to think it is not allowed in Southern CA because no one carries it.
    I can get it online but was trying to get it sooner because I have a leak in the main line to my house.
    Anyone know a place in the Los Angles area where I can get it?
    or a good online dealer.
  13. hj
    You have to find a plumber who has a roll of it and will cut off what you need. If your PE has that i.d., then it has to be IPS schedule size, but he would probably receive CTS sized pipe which has an o.d. of 1.125 and a relatively small i.d. due to the wall thickness.
  14. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I really don't know squat about PE pipe, but a quick online search shows JM Eagle PE pipe is sold in several places in Bakersfield as well as some other places reasonable close to you. I would recommend you consider a large size than 1". This is not a time to try to save a few dollars on pipe that may be a bit too small.
  15. tikicarver
    Feb 1, 2010
    Tehachapi, CA
Similar Threads: where pipe
Plumbing Forum, Professional & DIY Advice Where is my pipe clog? Low flow, low pressure. Nov 13, 2016
Plumbing Forum, Professional & DIY Advice re: Weeping tile pipe towards interior. where does it go? Oct 8, 2013
Plumbing Forum, Professional & DIY Advice Critters in the waste pipe - coming in from where? Mar 24, 2013
Plumbing Forum, Professional & DIY Advice where did you get fittings for PE pipe? Nov 4, 2012
Plumbing Forum, Professional & DIY Advice Leak where galvanized water pipe enters house through concrete foundation Oct 13, 2012
