Where to buy flexible plastic tubing?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by grizz, Jun 4, 2012.
  1. grizz
    grizz New Member
    Jun 1, 2012
    Colorado
    I'm currently putting pieces together for my 365ft well and was wondering where you guys buy 1 1/4" plastic tubing. It looks like my local home depot only sells the 1" size roll of plastic tubing but my pump has a 1 1/4" discharge. I've come across a few websites that sell it for an outrageous price, just wondering where the pros buy from. Thanks
  2. hj
    you do realize that there will be about 160 psi static pressure on the pipe where it connects to the pump, I hope. Then add the operating pressure of the system and you have a serious dynamic pressure to contend with, so you need GOOD plastic pipe AND connections.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Any plumbing supply house should have or be able to get it. Make sure the stuff you get is rated for potable water. There is a lot of PE that is not as such.
    You need to look at the head pressure for that depth. Most PE is not recommended for that deep.
    http://www.deanbennett.com/well-accessories-page21.pdf
  5. grizz
    grizz New Member
    Jun 1, 2012
    Colorado
    thanks for the replies! I didn't know about the 160 psi at the pump, is there a formula I can use to figure out what my exact pressure will be? It wont be hooked up to any pressure tank and will only be used to fill a water storage tank once in a while. Thanks for the help guys
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Every foot of water in a vertical pipe adds .433 psi. The height of water in a non-pressurized tank can be added the same way.
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I know the pump has 1 ¼” discharge, but that doesn’t mean you have to use that size pipe. If the pump will produce less than 15 GPM, I would use 1” pipe. It would be less expensive, less weight, has a higher burst strength, and probably easier to find.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I hang 90% of residential pumps on 1" - 160lb.
Similar Threads: Where flexible
Pumps and Tanks Well Forum & Blog. Water is life. Where to start with 50 year old well? Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Where to go with sump discharge? Apr 18, 2016
Pumps and Tanks Well Forum & Blog. Water is life. where to get 155031110 Nov 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Where can I find a 3" Swing check with BSP threads? Mar 3, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Where to buy threaded/flush pvc for well casing? Jan 2, 2015
