Pghsebring
DIY Member
So this is my dilemma...I've never half-assed anything before in my life, but I cannot take the time to fix this properly, even though I know how to.
I bought a house that has a 1.5" copper standpipe for the washer that is an s-trap and has no vent, no sanitee - oh, and the utliity sink drains into the same line downstream too (into a combo wye on its side of course) which would be wet vented if there was a vent. A total mess that was put in by a plumber - its all soldered copper drainlines. So basically, everything is wrong. Anyways, after the washer stand pipe p trap and the utility sink , the drain line goes around a corner, travels about 5ft, then around another corner, travels about 1ft, through a fernco into a 1.5" PVC pipe, and then it goes into a 4" x 4" x 2" combo wye that some A-hole stuck a 1.5" bushing in. I just can't win here. So, I can fix all that early mess and plumb it correctly in the laundry room. The problem is, I already broke out an 18x18 travertine tile to get to the fernco. To get to the 4" stack to replace the (now) 4x4x1.5 combo wye, I'd have to break out 2 more on the wall, and then, because the combo wye is so low into the ground, I'd have to start digging through 18" travertine tiles on the floor and start breaking up concrete, etc, etc, etc - make a total mess of the one room that is actually finished in this house. There is just no way to cut out the combo wye and put in a new 4x4x2 combo wye without destroying my bathroom. And for once, I just can't do that.
I know I need a 2" stand pipe for the front load washer and its supposed to be a 2" drain the whole way, but it just can't happen this time. So, my question is this: where is the LEAST WORST place to go from 2" to 1.5"? Is it right before the p trap for the washer? Right after the p trap? Just for that last inch when it goes into the 4x4x1.5 combo wye? Somewhere else?
Or did someone invent a drill bit so I can drill my combo wye back to 4 x 4 x 2?
I know, I know, I'm a bad DIYer. I apologize in advance.
