Where does my softener drain go?
Discussion in 'Water Softener Forum, Questions and Answers' started by rdhanson1, Jan 13, 2010.
  1. rdhanson1
    rdhanson1 New Member
    Jan 13, 2010
    iowa
    I live on an acreage with septic system and a deep well system and water softener in the basement. The water softener was installed in the house by previous owners. The drain line for the softener is connected to a 1" pipe that goes straight out the basement wall at about 1 foot off the floor. I don't know what this is connected to, but I'm concerned that wherever it is going it is getting filled up with salt and is slowing down the softener regeneration. Do you know where this pipe may be going? I know it is not going to the septic system and don't believe there are any drainage tiles around the foundation that it may be connected to either. The house was built in the '50s. Was there a standard drain method used back then? Maybe something like a cistern tank? Thank you...
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    maybe a dry well or into the perimeter drain.
  4. Gary Slusser
    Retired
    What evidence do you have that there is a problem? After 60 yrs if there is a problem, you'd certainly see evidence of it.
  5. rdhanson1
    Jan 13, 2010
    iowa
    I'm starting to see what looks like salt crystals forming along the bottom of the walls in the corner of the basement where the drain exits the wall. Also, the floor area is constantly moist and I have to run a dehumidifier to keep it dry. Was it a common practice to dump this salt water into the tiles along the footings? Wouldn't this eventually fill up the tile with salt and cause drainage problems too? If there are footing tiles, I don't know where they drain to but I suspect they are plugged up because we have been getting more rain water problems in the last 5 years. I can't find any records of how this house was built since it is 50+yrs old, but I suspect I'll have to dig up the area next to the foundation and see where the drain goes and if there are tiles also.
  6. Gary Slusser
    Retired
    I would disconnect the line in a way that allowed me to plug it so water can't come into the area from outside and then run a new drain line to a drain or sewer line.
  7. rdhanson1
    Jan 13, 2010
    iowa
    drain into septic system?
    The only drains I have go to my septic system, which is as old as the house(but still works). Is it a good idea to dump this salty water into a septic system, let alone an old septic system? The only other place I could dump this water is out in a ditch about 100 ft away.
Similar Threads: Where does
Water Softener Forum, Questions and Answers Gravel for water treatment , where to get Jan 10, 2016
Water Softener Forum, Questions and Answers 1" everywhere but a reducer after the softener Jan 1, 2016
Water Softener Forum, Questions and Answers Where to order Fleck softener and resin question. Aug 27, 2015
Water Softener Forum, Questions and Answers Where to purchase Fleck5600 Aug 20, 2015
Water Softener Forum, Questions and Answers Where to buy Big Blue *Valve-In-Head* Sediment Prefilter Housing Jan 19, 2015
