You need to read and comprehend the article from where you stopped quoting it down to where it starts talking about "soda ash". There is much more to 'lime softening than simply running water through soda ash or adding some soda ash. Especially in a residential application.
Here it is:
2.0 Description of Technology
The origin of lime softening dates back to 1841 when lime was added to Thames River water to reduce bicarbonate hardness by precipitation of calcium alkalinity as calcium carbonate and magnesium alkalinity as magnesium hydroxide. Modern day lime softening, referred to as the cold lime process, operates under the same principle.
The softening process typically includes pretreatment, softening, recarbonation, and filtration steps.
Pretreatment Pretreatment consists of either aeration or presedimentation. Aeration is necessary with waters that have high CO2 concentrations, such as ground water. Presedimentation is used with very turbid surface waters, in order to create a more consistent feed water quality.
Technology Description
In the softening step, the first chemical addition is quick lime, or CaO, which combines with H2O to form calcium hydroxide, or Ca(OH)2. The calcium in the water then reacts with CO2 to form a calcium carbonate (CaCO3) precipitate. The optimum pH for this process is about 10.3. Magnesium precipitation in the form of magnesium hydroxide, Mg(OH)2, requires a pH of 11.0 to 11.3. This pH can be obtained by using additional lime.
Solids contact clarifiers combine mixing, flocculation and sedimentation in a single basin and are commonly used for lime softening. Raw water and chemicals mix with previously formed lime slurry in a centrally located draft tube with impeller. Quick lime is usually in the form of pebbles, which need to be slaked with mixing equipment. Slaking creates a mixture of 2 parts water and 1 part lime slurry in a separate facility, which is then fed to the solids contact clarifier along with the addition of a coagulant. The coagulant could be iron based (ferric sulfate, ferrous sulfate) or aluminum based (aluminum sulfate or sodium aluminate). Sodium aluminate is the preferred coagulant if the feed water contains high sulfate concentrations. The water depths in solids contact clarifiers usually range from 14 to 19 ft, and contact time is typically 15 to 30 min. Surface loading rates typically range from 1.0 to 1.75 gpm/ft2. If coagulation for turbidity removal is required the surface loading rate is usually on the lower end of this range.
The water then passes through distinct zones within the basin for reaction, flocculation and clarification. Clarified water is collected in radial effluent launders which direct the flow to an effluent discharge pipe. Solids in the clarification zone settle to the bottom of the basin and are moved to the center by a rotating sludge rake.
Effluent pH from the lime softening process is around 10 to 11. A pH adjustment is required to reduce the pH to around 8. The pH adjustment is particularly important when using MF membranes since high pH water may induce scaling on membrane surfaces. The pH adjustment is performed by injecting sulfuric or hydrochloric acid into the effluent stream with a metering pump. Sulfuric acid is preferred over hydrochloric due to the lower dosages and costs required.
Soda ash (Na2CO3) can then be added to remove non-carbonate hardness, in a process known as second stage softening, which is prior to filtration as well.
I doubt he is doing any of that before using soda ash. Also, I doubt he is using any sulfuric and/or hydrochloric acid.
