I am building a workshop with a half bath about 75-100 feet from my main house. The workshop is on the same side of the house as the septic tank (approximately 50-75ft away from the tank inlet) but the problem is, with the grade of the property, the workshop is not high enough above the level of the septic tank to get proper gravity drainage.
I think I need to install a pump of some sort. Should it be a Grinder Pump or Sewage Ejector?
I've looked at both and while it's clear that an ejector would be lower cost, I want to install the correct pump for the job.
Also, I've read (on a Composting Toilet website) that output from a Grinder pump shouldn't be pumped into a septic tank because the solids are TOO mascerated and will flow out the drain side before settling... Any truth to this?
If I do install an ejector, where should the well/ejector be located? I don't want an above ground (AKA visible) Sewage Line and think that I'd need to place the well further downgrade (or deeper into the ground) so that the well is gravity fed and has some back pressure on the line to the septic tank.
Thanks in advance,
Tom
Thanks in advance,
Tom
