When to repair - when to replace?
shendrick
West of Bosston
I've got a 10 year old Sear Power Miser gas hot water heater. it's never had the anode changed and now we're getting yellow hot water. I'm guessing that the yellow water means that the anode is shot and the tank is rusting. If yellow water is a symptom of the tank rusting, I would assume the only option is to replace. Do I have this right?
JohnjH2o1
Florida
If it's been ten years since you purchased a gas water heater your in for some sticker shock.
John
shendrick
West of Bosston
I know, it will be about $1K for the heater plus a few hundred for installation. Question remains, is it really time to replace or would a new anode do the trick?
If the yellow is rust, it's unlikely a new anode will resolve the problem. But, first, is the hot water colored at every outlet? If not, it's not the WH, but likely the piping to the thing that does have the yellow water.
That may be more than an anode rod.
One thing you may do is connect a hose to the drain and see if you can flush the tank out.
shendrick
West of Bosston
Terry, thanks for the advice. The literature says something about a swirl acthitecture, so I'm going to assume that the significant yellow that we see is more than just sediment. After 10 years, I would suspect that the liner is cracked given how much yellow we see. I could fuss around with an anode, but it feels like a bandaid solution that buys me some extra months - not years. I guess its time for a do over before we need to build an ark.
Generally, if you have an issue with a water heater that is ten years or older, it's better to just replace it.
Not much bang for the buck doing a band aid job.
And I can say that because I did just that for my own home years ago. The band aid lasted two months.
IF a new anode rod would have prevented the condition, and that is not likely, then it is too late for that now. Once the tank starts rusting, an anode rod cannot stop it.
