When is a toilet vent not required?
Discussion in 'Canadian Plumbing Code Questions' started by grahamW, Feb 27, 2012.
  1. grahamW
    grahamW Member
    Jan 26, 2012
    Ontario, Canada
    Can anyone advise when a toilet vent isn't required in Ontario? I have a small 2 piece bathroom on the mainfloor and the toilet enters a 3" stack directly without a vent. The sink connects to this same stack and has a 1.5" vent.
    Thanks.
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    It does require a vent.
    The stack itself is likely 3" or 4", and I'm guessing nothing ties into it above your 2 piece bathroom?
    There are certain distances that must be adhered to, but the stack itself is venting the w/c for you here I imagine.
  4. grahamW
    grahamW Member
    Jan 26, 2012
    Ontario, Canada
    Thanks for the quick reply dlarrivee! Indeed, the 'stack' is 3" and only contains the toilet with the one sink connection. It directly enters the main sewage line beneath the slab. I have yet to find the sink vent but I suspect it is 1.5".
    I was hoping for a 2" vent so I could tie in new basement drain and a laundry tub/drain. It looks like I'll be putting a 2" vent up to the attic after all.
  5. dlarrivee
    Jun 28, 2009
    Canada
    You're better off trying to go straight up with your 2" vent than trying to tie into an existing horizontal one anyhow... you need to bore fairly large holes for 2" lines.
  6. grahamW
    grahamW Member
    Jan 26, 2012
    Ontario, Canada
    Thanks, the problem is that it isn't a straight, vertical run to my attic. Will need one major jog as the roof level is split. Oh, and I hate distrubing all that blown insulation up there.
  7. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    more than likely your sink goes directly into the 3 inch stack. and you dont have to run 2 inch for a vent
  8. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    you can run a 1-1/2" vent for what you want to add in the basement and tie it into your stack above flood level rim of the uppermost fixture (sink)
  9. hj
    YOU do not know venting, so why don't you get a plumber who DOES, and maybe he will install the vent the easy way. IT does NOT require a vent when your local code says it does not, but you have to contact your building department to find out.
  10. Plumber1979
    Jul 15, 2012
    Certified Plumber
    Ontario
    thats why hes here, to ask for help. dont be a dick plumber. and IT ALWAYS rewuires a vent, where did you learn plumbing
  11. MikeON
    MikeON New Member
    Apr 17, 2013
    gueph, Ontario
    Toilet can run up to 3m (9.8 feet) horizontally and maximum in changing direction of 225 degree before it needs a vent .
    2006 Ontario Code, part 7, sentence 7.5.6.3.(2)
  12. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    Just to add to this:
    The distance between the toilet connection (flange) and vent pipe can also be 1m vertical and 3m horizontal. meaning you can drop 1m on the vertical plane from toilet flange and 3m horizontally before requiring a vent connection
  13. MikeON
    MikeON New Member
    Apr 17, 2013
    gueph, Ontario
    Can it add up ? If it runs horizontal only, the maximum distance from the center of 3" elbow (just below the flange) to a vent is 4m ?
  14. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    nope...it will always run vertical.....think of your connection to flange = vertical. that is where you can go up to 1m....you can only go from that vertical to horizontal once...it cannot offset from horizontal to vertical again until after the vent connection
  15. hj
    quote; IT ALWAYS rewuires a vent, where did you learn plumbing
    I learned plumbing under a GOOD code, but a lot of people are working under the IPC, which is an "anything goes" code and therefore I have heard that it does not always require a vent for a toilet. Their thinking, apparently being, that since a toilet is an "S" trap already, a vent would not help it flush any better.
  16. Sean Beck
    Sean Beck Plumber
    Jun 14, 2013
    Toronto, Ontario, Canada
    It can. I queried this with my plumbing professor. He said it could drop 0.5m from the flange, run 3m horizontally and the drop 0.5 vertically before connecting to a vent.
Similar Threads: toilet vent
Canadian Plumbing Code Questions Venting Possibilities for basement toilet Jan 2, 2013
Canadian Plumbing Code Questions Properly venting a toilet in Canada Jul 3, 2010
Canadian Plumbing Code Questions Toilet Shower Sink drain venting, Canada Jun 29, 2010
Canadian Plumbing Code Questions toilet wet vent in Canada Jun 24, 2010
Canadian Plumbing Code Questions Composting Toilets Jun 3, 2016
