Eric B
I'm in the middle of an extensive reno of my Poodle Pink tile, 1957, master bathroom. It seems I have iron pipe under the floors in the crawl space. I've sledge hammered out the tile and poured cement basin for the shower. Now I have the drain pipe protruding about 4 inches up into the space. It's severely corroded and no wrench will ever get it out! Would you recommend that I cut the drain pipe under the house at the joint into the main drain pipe, or can I cut it at floor level and do some sort of PVC slip joint into the 2 inch drain pipe? I'm installing a premade shower pan into the space and will forego the re-pouring of cement and floating.
