What's the secret sauce on manuerving a Drop in Cast Iron Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by chefwong, May 11, 2013.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Cast Iron Standalone or Apron Tub. No Problem. Just shimmy and set it it's place...with tons of help.
    How about a 60" Cast Iron Drop In - with a working width of 60".....
    I do prefer the cast iron, as the missus likes the soak.
    Just wondering any tips on how to get a 300 pounder up and over when you only really have leverage on the front and some wiggle room
    with now walls nailed up, and you have your *hands* on the framing..
  2. chefwong
    chefwong Member
    Jun 14, 2006
    BTW, one more detail. Went tub shopping today...
    Unless all the floor models were installed to a certain spec, are tubs about 2" higher these days compared to previous yester-years models.
  4. Terry
    Aug 17, 2004
  5. chefwong
    chefwong Member
    Jun 14, 2006
    Heh. I remember that thread. Dropping and CI right on the floor is much much easier than.... figuring out how to life the beast for a drop in, with no room in the back and just *open wall* for hands on the other 2 sides. Might have to play around, cleat it from the drain and do some McGuyvering winching it up and over
  6. hj
    A 60" "drop in tub" in a 60" recess is a disaster waiting to happen, even if you install the "optional tile bead". You put the "cleats" on the back 3 sides, then slide it in, before finishing the front "wall".
  7. chefwong
    chefwong Member
    Jun 14, 2006
    OMG. I was thinking about the *box* and did not think about just the 3 cleats as the platform and then deal with the front from there.
    RO - etc to be built. So I should be good on that...
    HJ. A lifesaver. I suppose that CI is not entirely ruled out for the tub replacement versus acrylic.
  8. Terry
    Aug 17, 2004
    I skipped the part about this being a drop in tub. If you are tiling down to it, like putting it within three walls, you may have problems with water.
    Drop-Ins normally aren't for showering.
  9. chefwong
    chefwong Member
    Jun 14, 2006
    Any reason on not for showering - if Given the Premise that the construction of the walls to the tub will be waterproofed correctly.
    I have to dig some tech sheets. Was looking at a couple different tubs - have yet to decided on one.
    One was a drop it with a tile flange. I believe I was just going to choose the non flanged as was planning to make my own *flashing*
Similar Threads: What's secret
Shower & Bathtub Forum & Blog Different shower pan. What's the difference? May 18, 2016
Shower & Bathtub Forum & Blog What's better to bathe in Cabernet or Beaujolais? Oct 30, 2014
Shower & Bathtub Forum & Blog What's a good tub? Feb 12, 2014
Shower & Bathtub Forum & Blog Marble, granite, travertine, porcelain? What's best? Jan 13, 2014
Shower & Bathtub Forum & Blog Two tubs: what's the difference?? Oct 30, 2013
