What's the most reliable way to go from copper to pex without soldering?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amateurplumber1, Apr 15, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    Just curious to hear what you think is the best way to go! I know a lot of people wouldn't consider not soldering, though.
  2. Terry
    Aug 17, 2004
    I normally solder on a PEX adapter to copper pipe.
    However if you're not soldering, then you are looking at a sharkbite.
  4. teddy12
    teddy12 New Member
    Apr 15, 2013
    Richmond, VA
    Been very happy with my SharkBite adapters so far. Are you not trying to solder because of tight spacing or things nearby?
  5. amateurplumber1
    Mar 10, 2013
    Here
    To be honest, I have none of the stuff required and it's gonna be kind of expensive. That, and I have no experience soldering, and I want to get this project done. Thanks for all the info!
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Basic soldering "stuff" is not expensive. All you need is a propane torch, a can of flux, a tubing cutter, a roll of solder, and a roll of emery cloth or brushes to clean the pipe ends and fittings. Sweating joints is not a difficult skill to learn, even if your first efforts don't look pretty, they will work. A few practice fittings and a little pipe is all you need to learn.
Similar Threads: What's reliable
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Saturday at 10:38 AM
Plumbing Forum, Professional & DIY Advice Slab leak? If so, what's next? Jan 11, 2017
Plumbing Forum, Professional & DIY Advice What's the difference between these two overhead sewer setups Dec 7, 2016
Plumbing Forum, Professional & DIY Advice What's under my 1957 Floor boards !!! Jan 12, 2016
Plumbing Forum, Professional & DIY Advice Delta 13, 14, 17 - what's the diff? Apr 23, 2015
