What water heater for gravity loop?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mark_g, Mar 31, 2009.
  1. mark_g
    mark_g New Member
    Mar 3, 2009
    Locally, Rinnai and Noritz are available, and my plumber uses both. This is for new construction.
    In the house, we're thinking of installing a gravity loop system with a HW return, and for demand reasons, putting in a small storage tank (there will be occasional times when we need to run two showers and kitchen sink simultaneously). He isn't sure gravity loop will work with either unit. I don't want a pump.
    In a separate sm efficiency apartment, we're considering a CW return off a separate tankless unit, as that could prevent pipe freezeups in the winter?
    Anyone had experience with RedyTemp, ReadyHot, Red Lobster for either or both of these applications?
    Feedback appreciated. Installation is in upper NY State.
    Thank you, Mark
  2. hj
    heater
    Gravity recirulation systems DO NOT work with tankless heaters. It will work with the 6 gallon heater, IF it is installed correctly.
  4. jadnashua
    I've had a RedyTemp installed for about 5-years and it works fine. I have it on a 7-day timer so it only runs when I'm normally both home and awake.
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
