What type of pipe??????
Discussion in 'Pumps and Tanks Well Forum & Blog' started by derousseau, Sep 9, 2009.
  1. derousseau
    derousseau New Member
    Sep 9, 2009
    Texas
    I am wanting to install (in my Garage) A pump, pressure tank, and a 500 gal tank for the water to my house. I was wondering what type of pipe I should use to conect all this, copper, steel, or PVC?
    Thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    In order...Copper, then CPVC, then PEX.....Does your area ever freeze?
    500 gallons won't go very far...a larger tank would be much better...
  4. derousseau
    Sep 9, 2009
    Texas
    I'm in Texas. We might get 1 or 2 nights that could freeze, but I can insolate the pipes.
  5. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    Is your water acidic? If so you should not use pipe that will be affected by the acidic water--like copper.
    For the piping within the garage I would think that standard schedule 40 PVC would be a good choice because it does the job and is less expensive than the alternatives. For the pipe from the garage to the house I would be inclined to use the same pipe if the garage is attached to the house or black PVC that is used in wells if the garage is a free standing structure. Black PVC has a degree of flexibility and is relatively inexpensive and usually easier for underground runs. All of the foregoing assumes that these materials are allowable under your local codes.
  6. derousseau
    Sep 9, 2009
    Texas
    Why not 40? Does it have to be 80?
  7. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    CPVC within the structure.
  8. Bob999
    Jul 4, 2009
    Pennsylvania
    Is this a code issue? Schedule 40 is widely used in my area (Eastern PA).
    I did a search and found the following information:
    "Code information. Model plumbing codes sponsored by associations of enforcement officials or other industry groups are the basis for most of the more than 14,000 local codes in the United States. Every model plumbing code in the United States approves the use of PVC pipe.
    PVC pipe is permitted to be used in any water service system, without limitation, in the National Plumbing Code (Building Officials and Code Administrators International), Uniform Plumbing Code (International Association of Plumbing and Mechanical Officials), National Standard Plumbing Code (Plumbing-Heating-Cooling Contractors Association) and Standard Plumbing Code (Southern Building Code Congress International). "
    The above quote came from this site:
    http://www.vinylbydesign.com/site/page.asp?CID=95&DID=105
  9. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Bob, sched 40 PVC isn't rated for hot water.
  10. Bob999
    Jul 4, 2009
    Pennsylvania
    Agree.
    I didn't see anything in the original post about hooking up hot water and ASSUMED that the 500 gallon tank referred to was not a hot water tank.
    Are we in agreement that Schedule 40 can be used, even within a structure, for cold water?
  11. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    In Florida (which seems to be identical to IPC), distribution piping within the building cannot be Schedule 40, it has to be CPVC. Service piping to the building can be PVC.
  12. Bob999
    Jul 4, 2009
    Pennsylvania
    As I understand the code issue the distinction is between "service" piping and "distribution" piping. So I guess the practical question is where the dividing line is in a residential installation--for example, in the case of a well is it before the pressure tank or is it after POE water treatment equipment like a retention tank and whole house filters?
  13. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I hardly ever deal with well systems. In a traditional system the service pipe is the pipe up to the structure. Everything within the structure is distribution piping.
  14. derousseau
    Sep 9, 2009
    Texas
    Everything I'll be installing is outside of the house in a detached garage. It will tie back into the pipe before it goes into the house and the water heater.
  15. Bob999
    Jul 4, 2009
    Pennsylvania
    In our area acidic water is quite common and it attacks the copper and leaches it into the water--not something you want in your drinking water. The choice of plastic over copper at least up to the acid neutralizing filter is a matter of health, not money.
  16. Gary Slusser
    Retired
    I would use PE pipe or sch 40 PVC but, do you have city water or your own well?
    Are you aware of the maintenance (cleaning and sanitizing) the 500 gal tank will require? How about potential water quality problems?
  17. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    My codes and charts say you can use Sch. 40 PVC for supply piping. As far as I know 2009 IPC says the same thing.
  18. Bob999
    Jul 4, 2009
    Pennsylvania
    Please post the relevant code. The code I can find says sch 40 PVC is approved for supply piping.
  19. Gary Slusser
    Retired
    I'd say you do have to post it. Maybe it's not used for either in Maine but all across this country it is used for water supply. In frost free areas across the south you can see it coming out of the ground at well pressure tanks out in the yard and along side the house/garage for city or well water supply and in cellars to pressure tanks and into garages where there is no cellar to water treatment equipment.
  20. Cass
    Cass Plumber
    Nov 12, 2005
    Water being supplied by a county or city or Water Supply Company are under different rules than home owners.
    Around here from time to time I see meter pits pig tailed with PVC...but from that point on and into the house we are not allowed to use PVC.
  21. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    both the IPC and Upc code do not allow PVC within a structure.
    IPC Table 605.4 and 605.5 neither lists PVC as an acceptable material.
    Your county, city or state may have adopted ammendments to such.
    That you see it all the time does not make it to code. I see water treatment equipment drained into unvented traps all the time. In fact, I see all kinds of code voilations all the time. Just one of those things those of us with licenses notice.
Similar Threads: type pipe
Pumps and Tanks Well Forum & Blog What type of pipe for 180' well? Mar 15, 2009
Pumps and Tanks Well Forum & Blog types of Plastic pipe available for deeper wells Jan 11, 2009
Pumps and Tanks Well Forum & Blog Best type of pipe? May 17, 2007
Pumps and Tanks Well Forum & Blog what type of pipe inside Feb 23, 2006
Pumps and Tanks Well Forum & Blog What type of Well pump? Jan 16, 2016
