What type of home insulation should I purchase?
Discussion in 'Remodel Forum & Blog' started by eastinway, Jan 23, 2009.
  1. eastinway
    eastinway New Member
    Jul 7, 2008
    Hi folks,
    I would appreciate advise on what type of home insulation I should buy. I'm concerned about breathing in chemicals contained in foam insulation. What would be the most economical way to go.
    Also, can I insulate my garage. It is built into the home and I have a bedroom that sits directly on top of the garage which is always cold.....
    :)Thank you
  2. jadnashua
    The only gotchas in a garage are that the walls and ceilings between it and living space must have an approved fire barrier, typically 5/8" fire rated drywall is used (and a fire rated door into living space). So, depends on what is there now.
  4. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    The most economical way would be to used fiberglass insulation. The best way would be to use foam. It's my understanding that foam insulation isn't DYI type project.
    Yes you can insulate a garage.
  5. eastinway
    Jul 7, 2008
    Is foam insulation safe....
    Thanks Jad and S for your replies.....
    Just wondering is foam insulation safe?
  6. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    The early/first foams had outgassing issues (toxic fumes long after install), and could burn. But nowadays those issues have been taken care of.
    Not very safe for your bank account balance, though.
Similar Threads: type home
Remodel Forum & Blog Choosing window types May 30, 2016
Remodel Forum & Blog What Type of Roofing is the Best Suitable and Long Lasting? Jun 9, 2015
Remodel Forum & Blog What type of insulation under new laundry room "closet?" Feb 23, 2013
Remodel Forum & Blog Need source for window balance spring - old coil type - 50 years old Nov 7, 2012
Remodel Forum & Blog Subfloor type? Thickness? Drywall? Feb 2, 2012
