What type of DWV PIPE used in Canada
Discussion in 'Canadian Plumbing Code Questions' started by poky1234, Jan 7, 2013.
  1. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Hi ,
    I am going to do a small washroom reno and was wondering what type of 3 inch DWV pipe should be used in the DWV system above the basement concrete floor, ABS OR PVC . I have 4 inch PVC under the concrete. Located in Ontario, Canada.
    Thanks,
  2. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    we generally use ABS for anythign above ground in a residential building
  4. JTlikestobuild
    JTlikestobuild New Member
    Feb 18, 2013
    Vancouver BC
    Here in BC, ABS has been the standard for a long time but Sytem 15 PVC has made big gains. The PCS is quieter than ABS.
  5. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Thanks for the replies guys!
  6. MikeON
    MikeON New Member
    Apr 17, 2013
    gueph, Ontario
    QUOTE=mikeplummer;366388]we generally use ABS for anythign above ground in a residential building[/QUOTE]
    In Ontario, can we use ABS underground ? for example, building drain (horizontal sections underground) can be ABS or have to be PVC (white or green in color) ?
  7. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    In Ontario, can we use ABS underground ? for example, building drain (horizontal sections underground) can be ABS or have to be PVC (white or green in color) ?[/QUOTE]
    my original post said for anything ABOVE ground - but to answer your question - yes ABS can be used for underground, but PVC sewer pipe is mainly used underground, especially for the building drain
Similar Threads: type PIPE
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Vent pipe size - Alberta Jan 9, 2015
Canadian Plumbing Code Questions water pipes below electrical panel Oct 6, 2014
Canadian Plumbing Code Questions Use of Copper Potable Water Pipe Underground Apr 29, 2014
Canadian Plumbing Code Questions need help. Can drain pipes be in an outside wall? Nov 12, 2013
