What type of drain below hot water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by spresco, Jan 13, 2009.
  1. spresco
    spresco New Member
    Jan 28, 2007
    What type of drain should be used below a hot water heater? A standard p-trap below the floor would have a tendency to evaporate out allowing sewer gasses in so what type is usually used?
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    If you want to do it correctly, then a p-trap is mandatory, but you also need to use a trap primer to keep that p-trap primed.
    Some codes will actually allow the homeowner to forgo the use of a trap primer so long as they manually fill the trap from time to time, but that is not exactly a reliable method since the homeowner will quickly forget all about it.
  4. ArtM
    ArtM Junior Member
    Jan 10, 2009
    General Contractor
    East Slope of the Rockies
    Fill the trap with mineral oil. It won't evaporate out like the water will.
  5. Ladiesman271
    Ladiesman271 Homeowner
    Aug 22, 2008
    Care and maintenance of transformers
    I don't have a floor drain in my basement for my water heater or anything else. The sewer pipe outlet is a few feet higher than the basement floor level, so it impossible to use one in my basement anyhow!
Similar Threads: type drain
Plumbing Forum, Professional & DIY Advice Type of closet flange for 3" copper drain? Feb 18, 2014
Plumbing Forum, Professional & DIY Advice What Type Of Drain Pipe Is This & What 90 to Use Jul 31, 2012
Plumbing Forum, Professional & DIY Advice Best drain type and strainer for kitchen sink? Jun 9, 2012
Plumbing Forum, Professional & DIY Advice p trap type for shower drain Jan 7, 2011
Plumbing Forum, Professional & DIY Advice Plunger-typer lever drain Nov 19, 2009
