What type of connector do I need?
Discussion in 'Irrigation / Sprinkler Forum' started by Dar, Oct 25, 2009.
  1. Dar
    Dar New Member
    Oct 25, 2009
    KC area
    I'm having a tough time understanding what type of connector I need to hook my compressor to the sprinkler system. Here is a picture of where I need to connect. Any help would be greatly appreciated.
    [​IMG]
  2. hj
    connector
    You need an adapter that fits that socket, usually it will be a hose valve adapter. You will have to determine the make and model, then contact a supplier of that line to see if they have something other than an irrigation head which will go into that device. once you have the adapter, THEN you can get whatever it takes to convert it to your air hose.
  4. BRD
    BRD New Member
    Jun 22, 2009
    irrigation contractor
    northeast
    What you have there is a quick coupler valve connection. You will need to contact a irrigation supply house and purchase a brass quick coupler key. You will have to give them the brand and model #, which should be on the plastic cover. It appears to be a double lug QCV. " It also appears to be a 3/4" size. Keys are pretty standard, so another brand will probably fit. The key is inserted into the coupler and turned a half turn which opens a spring loaded check valve. You can then blow air thru it. As mentioned in the first reply, you will have to make up your own adapters to fit the key and your air hose connection.
  5. Dar
    Dar New Member
    Oct 25, 2009
    KC area
    Okay. Thanks for your help.
Similar Threads: type connector
Irrigation / Sprinkler Forum What type of backflow device is this? Apr 4, 2015
Irrigation / Sprinkler Forum Looking for a sprinkler type that sprays across and down Apr 16, 2014
Irrigation / Sprinkler Forum Flower Bed Remote Faucet: what type of piping to use? Oct 24, 2011
Irrigation / Sprinkler Forum Who makes the best Rainbird type sprinkler head? Jul 16, 2011
Irrigation / Sprinkler Forum Best type of drip emitters for very hard well water? Jul 27, 2008
