What torch do I need?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DavidTu, Jun 15, 2010.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    I've decided to replace a short section of pipe that is quite corroded inside and/or has lots of deposits on the walls. (This was my previous "leprosy" post.) Anyway, what sort of torch do I need in order to loosen up the old oakum and lead joint that connects this pipe to a very heavy-duty Wye (right before it exits building)? Also, please give your tips for how best to do it.
    I'm not clear if there are different torches for copper vs. cast iron joints... different temperatures... different flame shapes, etc? Please advise.
  2. Terry
    Aug 17, 2004
    You are better off drilling the lead and using a screw driver to pry the old lead out.
    Just because you heat the pipe up, it doesn't always mean that the lead will be smart enough to fall out of the joint.
    It takes a big torch to heat up a 4" cast iron pipe.
    I don't even try.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Big as in a #7 rosebud tip which takes a lot of gas to feed such as a professional welding
    shop may have !
    Do what terry says and drill it out !
    By the way when using a big torch you have to be aware of methane gas coming up the
    sewer pipe !
  5. hj
    An oxy-acetylene cutting torch so you can use the oxygen lance to blow the melted lead out of the joint. Otherwise the torch will just melt the lead and then it will harden just like it was.
  6. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    There is a tool called a lead pick but finding one is near impossible. Mephisto tool might have one
  7. 3m
    3m New Member
    Mar 3, 2009
    NY
    You also run a chance of cracking the cast iron with a torch
  8. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Thanks everyone for all your advice--especially the bit about not blowing myself up, would not have thought of that! I ended up drilling it out as per Terry's suggestion. It worked all right but took a while and killed two bits.
    Now I need to find a Fernco or other donut-style fitting to mate the old and new CI pipes.
  9. hj
    NEVER cracked a cast iron hub with a blowtorch OR a cutting torch.
  10. steelers fan
    steelers fan In the Trades
    Dec 11, 2009
    va
    I have actualy pulled them with a #2 on a mc tank
Similar Threads: torch need
Plumbing Forum, Professional & DIY Advice Need to find high output torch for 2" copper Feb 19, 2014
Plumbing Forum, Professional & DIY Advice Torch head for propane vs. mapp? Jul 5, 2016
Plumbing Forum, Professional & DIY Advice Torch/solder temp Jun 13, 2016
Plumbing Forum, Professional & DIY Advice Which soldering torch.... Apr 21, 2016
Plumbing Forum, Professional & DIY Advice Propane torch has wonky flame issue Feb 8, 2016
