What toilet will fit here? Shutoff in floor.
The OD of 1/2" copper is 5/8", and, depending on the type (common ones are K, L, or M), that isn't 1/2" either. The only thing that is standard is the OD.
Gary Swart
Yakima, WA
Stops are readily available at hardware stores, so you could wait until the old one could be removed and take it to the store to be sure of getting the right size. Hard to say for sure, but what it looks like to me is 1/2". As far as water supply is concerned, it won't make any difference when refilling the tank after a flush.
Brian Hartman
Denver, Colorado
Alright...I finally got more information and with further measuring and it looks like the Promenade will probably squeak in, clearing the floor mounted supply by barely 1/4" after removing the escutcheon.
When the plumber arrives, I'll have the toilet, wax ring/bolt kit, replacement braided connector kit at the ready.
I'd also like to have on-hand the correct 1/4 turn ball valve replacement. I looked at the existing Eastman Speedflex gate valve for any markings but couldn't find any. From the picture, could anyone tell me what valve I should get? A link or part number would help.
Did your Toto end up fitting?
