Dan Nolan Sr
Dan Nolan
Since moving into our latest home, our 2009 Kohler 2 piece toilet (31117173-6-A) has backed up and overflowed twice inside 4mos. My standard drain snake no good, had to call real plumbers. First one took several hours(make that dollars) and said if re-occurs, next time bring a camera.
Next time they found evidence of accumulation near a joint about 15 ft from this toilet. (Note all other fixtures in house including 2nd bath, drain perfectly). this plumber says I have some standing water in front of this joint and can only correct problem by jack hammering concrete floor in the dining room to get at it for repair.
Our 2009 Kohler toilet with a sticky complicated flush valve (#1117210) has been worked on several times before and should be replaced . It also says on bowl its a 1.6 GPF but inside the tank is stamped 1.28GPF. One thing I know, it hardly flushes at all. So, I'm hoping to correct the back up problem with a stronger flushing toilet. Question: will a TOTO 2pc 1.6GPF model help? Or should I consider an Assisted flush toilet? What would you recommend besides tearing up the floor?
Thanks for your advise,
Dan Nolan
Deland Florida
Dan Nolan
Deland Florida
