What to do with a leaking Mansfield 160
Discussion in 'Toilet Forum discussions' started by Tollerplumbing, Aug 29, 2013.
  1. Tollerplumbing
    Tollerplumbing New Member
    Jan 29, 2013
    WNY
    I bought a 7 year old house with a Mansfield 160 in the basement. The former owner only used the house occasionally in the summer and I doubt the toilet has been flushed 50 times.
    Today I noticed water running every 5 minutes for about 10 seconds and traced it down to the toilet. I played with the flush valve and it stopped leaking, but I doubt it is a permanent fix.
    They sell replacement flush valves for $9 and flush valve seals for $2. Do I need a new flush valve, or is the seal likely to be adequate?
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Most likely you just need to change the seal on the flush tower. (The least expensive solution, and it's usually all you need.) It's easy to do with the Korky 427BP replacement seal. See my responses 9 and 21 in this thread: http://www.terrylove.com/forums/showthread.php?50945-Toilet-Never-Stops-Running/ The suggestion made by Redwood that I link to in response number 21 is a little trick for getting the seal on correctly. The guy I was helping tried the trick after not getting the thing to stop running after replacing the seal, and the trick worked perfectly, so all the discussion about new flush valves, etc., was totally unnecessary. All he did was replace the seal, and then use the trick to make it seat properly, and for a couple of bucks he was leak-free.
    If you need me to break it down more for you, just ask.
    Good luck and let us know how it goes.
    (Unlike the guy in that thread, you most likely do NOT need a new fill valve as well.)
Similar Threads: leaking Mansfield
Toilet Forum discussions Mansfield, Leaking in tank - water will not shut off Sep 11, 2015
Toilet Forum discussions Mansfield 160 w/New flush valve and gasket is still leaking Oct 14, 2009
Toilet Forum discussions Kohler toilet makes leaking sounds, but never refills Mar 28, 2017
Toilet Forum discussions Toilet Ring Leaking in Rental House Jan 3, 2017
Toilet Forum discussions Flushmate external regulator leaking Nov 18, 2016
