What solvent/cleaner to remove duct tape adhesive from acrylic tub?
Discussion in 'Shower & Bathtub Forum & Blog' started by chassis, Nov 10, 2007.
  1. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    I foolishly used duct tape to secure a drop cloth while installing mud walls in my tub alcove. The tape left some adhesive goo. What solvent or cleaner can I used that won't damage the acrylic finish?
    I'm a big fan of Goof-Off, but this is the chemical xylene, which I think is a solvent for acrylic and would damage the tub. In my arsenal I also have mineral spirits, turpentine and acetone. HD/Lowe's is not far so I can run out and get something else if needed.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Goo Gone. Citris-based and won't harm the finish.
  4. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    Verdeboy,
    Thanks, it worked. Not real aggressive stuff, but it works.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    My favorite solvent cleaner is Zippo lighter fluid...( the yellow plastic bottle.) I keep several around the house and the truck.
  6. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    Thanks jimbo. I looked it up and seems like lighter fluid is naptha. Will it damage the acrylic tub finish? Something else to add to my selection of solvents.
  7. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    As long as you're adding to the arsenal... acetone.
  8. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    frenchie,
    Thanks. Yep I'm a fan of acetone (for cleaning tasks), and have a can sitting in the garage.
  9. jimbo
    jimbo Plumber
    San Diego, CA
    The goo gone and the Zippo are safe for most surfaces, including most plastics and finished wood surfaces. NOT true for acetone!
  10. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I use my wife's nail polish remover (acetone) on surfaces that I don't care about, but I also use Goo Gone and Oops!, which are basically similar citrus-based stuff, for tub/shower and sink surfaces.
    Goo Gone will even instantly remove clear silicone caulk off of your hands better than gasoline, which is what I used to use years ago.
    That stuff is amazing.
    Mike
  11. Jackie07
    Jackie07 New Member
    Oct 28, 2007
    Missouri
    Cooking oil will break down adhesives and allow them to be removed from a surface without harming it so long as it is a non-porous surface.
  12. steelwire
    steelwire Guest
    Thanks jimbo. I looked it up and seems like lighter fluid is naptha. Will it damage the acrylic tub finish? Something else to add to my selection of solvents. stainless steel pipe stainless steel wire
  13. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Lighter fluid works good used it for years helps finish out silicon caulk.Will not harm any surface.
Similar Threads: solvent/cleaner remove
Shower & Bathtub Forum & Blog How to remove cartridge? Wednesday at 10:30 PM
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Feb 20, 2017
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog What is this part and why can't I remove it? (Moen shower 1225) Mar 31, 2016
