What size water heater needed for Jacuzzi?
Discussion in 'Water Heater Forum, Tanks' started by wrdrennan, Apr 26, 2012.
  1. wrdrennan
    wrdrennan New Member
    Apr 26, 2012
    Shoreline, WA
    I plan to install a 55-gal jacuzzi tub. What size water heater do I need, gas, tank?
    4 people in the house, 1 bath, might add 3/4 bath in 5-10 years. I'm thinking 75-gal, but that might be over kill. Maybe 65 would cut it fine?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    With a condensing gas water heater w/~75KBTU/hr burner you should be able to get there with a 50 gallon. For non-condensing burner (any rating), 65 works, but if it has less than 50KBTU/hr burner you might have to wait for it to recover after filling the tub before somebody in as-yet built second bath could take a shower.
    If you wanted margin, the 100KBTU/hr burner version of the condensing 50 gallon Vertex has a higher first-hour gallons rating than most 75 gallon tanks. You may have subsidies available to you for going with a condensing water heater too. A 100K condensing burner can run ~3gpm (about 1.5-2 low-flow showers) of 110F water forever at typical Seattle area incoming water temps.
  4. imeot
    imeot New Member
    Dec 3, 2011
    Slovakia
    Hi, based on my humble opinion for a jacuzzi I'd use a tankless water heater. That way you could get on-demand hot water whenever you need. Since you have a relatively large house I'd think about buying a high-end tankless water heater. Probably the Rinnai tankless water heater - R94/RL94 (and above) would be a safe bet, such a heater could handle all the prerequisities you set up in the opening post. And last but not the least the extra price you pay for a tankless water heater will return as a saving on a longer run.
  5. BrianK
    BrianK New Member
    Jun 4, 2012
    Calgary, Alberta, Canada
    You could also install a second 40 gallon tank in series with your other tank. I did that and we have lots of water. The nice thing about 2 tanks is that if one goes, and if you installed bypass valves, you will still have hot water and you have some time to replace the failed tank.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    2 cheap forty's. Always best to design with backup, and can turn one off when the JAQ is out of service or you go away.
Similar Threads: size water
Water Heater Forum, Tanks Trying to get verification on water heater wire size Aug 25, 2015
Water Heater Forum, Tanks Water heater size with and without tempering valve Jul 12, 2014
Water Heater Forum, Tanks New Water Heater: Traditional Vent vs Power Vent, What Brand, What Size Nov 15, 2013
Water Heater Forum, Tanks what size hot water heater for a spa shower Mar 21, 2010
Water Heater Forum, Tanks Hot water recirculation loop size? Jan 18, 2010
