what size sewer line???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bradl, Aug 14, 2006.
  1. bradl
    bradl New Member
    Aug 14, 2006
    current home is approx. 35-40yrs old slab construction and does not have a cleanout installed within 5' after it leaves the slab.
    I dug up the line and see it as hub/spigot cast iron(checked with magnet), but it measures 5" O.D. exactly!??
    I want to cut in a wye but todays modern fittings would leave a lip on the I.D. (ie.,4" Wye)
    I'm really confused as to:
    1. what size line is this? ( I checked a 4" Heavy Wall, but it has a smaller O.D.)
    2. How to accomplish what I need to do.
  2. jimbo
    jimbo Plumber
  4. bradl
    bradl New Member
    Aug 14, 2006
    From this chart it appears that this could be Class B(5" OD, 4.12" ID), C or D cast iron pipe , but the problem is matching the ID with
    the fittings you can purchase today. This would mean approx. 1/8" lip on a 4" wye (3.94" ID) that I can get from a plumbing supply shop.
    -This is being done because last year the township cut in a clean out at the curb line and the line backed up a few months later. Now I'm
    realizing that the same issue probably exists there and I thought I would be able to put a smooth transition clean out at the house (instead of
    having to pull a toilet to run a snake).
Similar Threads: size sewer
Plumbing Forum, Professional & DIY Advice Sewer line pipe size Jun 7, 2005
Plumbing Forum, Professional & DIY Advice Vent size? Tuesday at 8:49 PM
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Sanity check on pipe sizes for new construction Nov 26, 2016
Plumbing Forum, Professional & DIY Advice New construction main waterline size 900' from meter Oct 3, 2016
