What size sediment screen for my deep well pump?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Timbuktu, Jun 21, 2012.
  1. Timbuktu
    Timbuktu Member
    Jun 20, 2012
    PalmSprings SCal
    One of these days my deep well submersable will fail and require a "well man" to pull'er up.
    So i can be prepared for that day I should be researching now ,the kind of sediment filter that id have them replace the current one with. Thats assuming i have a "mesh size " choice .
    Of course theres no way of knowing what smaller size i need unless I know whats on it now.
    You know,I did save some sand that came up a few days ago,so i could take that sample into a dealer who could size the mesh using my sand sample. right?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you have course sand, sometimes it is better to use two filters. A large one with a course screen ahead of one with a finer screen.
  4. Timbuktu
    Timbuktu Member
    Jun 20, 2012
    PalmSprings SCal
    I assume there is supposed to be a sort of screen filter where the water first enters the well pipe down below.
    Is there a place online you may know of where I can see whats available ?
    or.. Is it better just to wait until the pump fails and has to be pulled up. Then whoever i call out to pull up the pump will be able to recommend a new filter screen then.?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Good well casing with screen or perfs should be the screen that keeps sand out of the well. But if it pumps sand, then you have to filter above ground. Lakos makes a seperator that fits on the pump. But you will need some open hole below the pump for it to drop the sand into.
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Is this a mud or rock bore? A rock bore would not use screened casing. If a rock bore, it might be top fed so putting a sleeve on the pump may help.
    If it is a mud bore, the well may need some further development by heavy over-pumping. That said, some wells may never clear up and so a dole valve and in-line filters might be the only option.
  7. Timbuktu
    Timbuktu Member
    Jun 20, 2012
    PalmSprings SCal
    I have no idea. Im in decomposed granite. High desert mountains. Never seen mud here,plenty of rock and sand.
  8. lebatard
    lebatard New Member
    Jun 27, 2012
    New York
    I agreed with the 2 screen idea. First use the more coarse screen as a first layer of protection and behind that, use a very fine wire mesh. Try something like a 100 x 100 stainless steel wire mesh that might be found here:
    http://www.bwire.com/
    These 2 layers of screening and filtration should be enough to keep both large and small sediment from causing this catastrophe that you are preparing for. Cross your fingers and hope you have a lot of time before this occurs.
Similar Threads: size sediment
Pumps and Tanks Well Forum & Blog. Water is life. Sediment particulate size test? Nov 12, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Wire size fact check Mar 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow pump intake size May 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Is larger pipe size a problem with a well? Mar 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank size Oct 25, 2015
