what size pressurized water tank?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Noahsoak, Aug 30, 2009.
  1. Noahsoak
    Noahsoak New Member
    Jan 19, 2009
    have an old galvanized water tank - small tank possibly only 32 gal. maybe 40 the flow test on the well when i bought house shows only 6gpm from well. what size pressure tank should I buy? am thinking of just leaving old tank in place and just tying in the new tank (suggestion from neighbor) then he said, i would have both tanks with water so the pump would have to come on less frequently - 1/2 hp pump
    the psi (?) is 40/60 - a well guy came out to install a new tank - but there was no room to get one in, the old tank is in a closet in a mud room - so he showed me how to open the tank to get air in (no shrader valve) - to cure the water log problem - he saved me alot of dough -
    my neighbor has offered to help me with it - but i am unsure of the size i should buy
    thanks for your input
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you have smelly water you need to stay with the same size and kind of tank. If it is just a galv tank because it is an old system, you can switch to a bladder tank. Switching to a bladder tank means you have to do away with the air charge components.
    If you switch to a bladder tank, you can use a Cycle Stop Valve and then you only need a 4.4 gallon tank as in the one pictured above.
  4. Gary Slusser
    Retired
    He probably measured the 6 gpm through a 1/2" drain valve at the tank.
    If so, that is not an accurate way to determine the gpm. And that is what you use to size a 'bladder' type tank.
    Is your 1/2 hp pump a jet pump or submersible? Do you know anything about the well depth of pump depth? What diameter well? Static water level?
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You should put the largest tank in that will either fit or that you can afford. Larger tanks = longer pump cycle times. Longer pump cycle times = less $ for electricity to operate and longer pump life. The only exception would be if the well could not produce enough water to fill the tank but that's pretty rare. One more thing. Drop the pressure switch to 30/50. 40/60 is pushing it for a shallow well pump.
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    I use to be an advocate of larger tanks but, not anymore. You will actually get longer cycle times, which means longer pump life, when using a CSV and a small tank. The longer run times for small amounts of water might increase the electric bill a couple of bucks but, you can’t save enough to ever pay for the added expense of the larger tank.
    Manufacturing pumps and tanks uses a lot of energy, and making pumps last longer and reducing the tank size required will also save energy. This savings just shows up as a decrease in overall cost of materials, instead of actually on the electric meter.
  7. Noahsoak
    Noahsoak New Member
    Jan 19, 2009
    when we bought this place this is what the flow test report said
    casing size 6 in. static level 14 ft.
    depth 200 foot (per seller) - pump depth 100 ft.
    pipe dia. @ well head 1 inch
    test times start 1 pm - stop 6 pm
    test comprised an unrestricted discharge and regulated discharge, both at well head
    unrestricted disc. indicated well is capable of supplying 8 to 10 GPM
    regulated disc. performed at 4 hour period at rate of 6 GPM
    system produced 6 GPM consistently over 4 hour test - pressure tank is a small 40 gallon tank without a bladder
    that's the skinny
    the well/pump guy that came out - suggested 32 gal. steel tank
  8. Noahsoak
    Noahsoak New Member
    Jan 19, 2009
    forgot about the pump type - this is a 4" submersible pump - 1/2 hp
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    Then I would suggest at least a 32 gallon tank. And since the well man suggested a steel tank, he probably knows there is something in the water that needs to be mixed with air to prevent smelly water. If that is the case, don't use a bladder tank.
  10. Gary Slusser
    Retired
    IMO the test is showing the well recovery rate.
    I've never seen an OK 1/2 hp submersible pump deliver only 10 gpm open discharge with a static water level of 14'. And then only 6 gpm "regulated discharge" unless he all but shut the 'regulating' valve off.
    I suggest a CSV instead of a much more expensive pressure tank that you don't have space for anyway.
    And if you have iron in the water, don't use a "Steel" air over water tank. Doing so will cause rusty water.
Similar Threads: size pressurized
Pumps and Tanks Well Forum & Blog. Water is life. Shallow pump intake size May 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Is larger pipe size a problem with a well? Mar 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank size Oct 25, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Wild fire guessing details on pump and on well capacitor start box size Sep 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Size of well seal ? May 31, 2015
