What size pipe can I put through a 2x4
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pmccurdy, Jul 8, 2005.
  1. pmccurdy
    pmccurdy New Member
    Jul 8, 2005
    Research Scientist
    Fort Collins
    I am finishing my basement. I put in an inside wall for a bar with a sink. I need to run my drain pipe through the wall. Can I run a 2" drain pipe through a two by four?
    Thanks for any help,
    Pat McCurdy :)
  2. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    The od of a 2 inch plastic pipe is 2 3/8 inches, you will need at least a 2 1/2 inch hole which leaves you with 1/2 inch on either side (obviously). Just make sure that you have nail guards in place so that you don't end up with a drywall nail through your pipe.
    King
  4. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
  5. pmccurdy
    pmccurdy New Member
    Jul 8, 2005
    Research Scientist
    Fort Collins
    Appears to not be possible
    Looking at the guidelines it appears it is not possible to put a 2" drain into a 2x4 wall. Is there another way to do this? Could I put steel plates on either side of the wall to support the pipe and then have less greater the 60% bore?
  6. jrejre
    jrejre New Member
    Dec 23, 2004
    Minnesota
    Why do you think that it is not allowed? The link has Figure 3 showing exactly what you are talking about. The note on Figure 3 says:
    "60% allowed in any non-bearing wall or in bearing walls with not more than two successive studs bored and doubled."
    Your situation is more complicated than that??
  7. dx
    dx General Contractor
    Jul 4, 2005
    General Contractor
    Michigan
    Pat,
    Are you trying to go through a vertical 2x4, the horizontal (bottom) 2x4, or both? Keep in mind that in a basement, it's extremely rare and unusual to have a load-bearing stud wall. All your 2x4 is doing is supporting drywall. So, for an oversize hole in a vertical stud, just use appropriate blocking above and below the hole to support and stabilize the stud. For a bottom 2x4, it is sufficient to nail the 2x4 to the concrete slab a couple of inches either side of the hole.
    Around here, in new construction, the pipe stub goes in the slab first. Then, the wall is framed around the stub. There is no hole at all in the bottom 2x4, it just stops and starts again on the other side of the pipe. As long as it is properly nailed to the slab, it passes inspection just fine.
  8. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    If this is a 2x4 stud, then you will need at least 2-1/2" hole and probably something bigger (2-3/4" say). There is no way you can do that and stay in code, even with a non-load-bearing wall, and remember, code is a minimum.
    You're going to have to make that a 2x6 wall, or leave it as a piece of hack work for some future owner to worry about (say when he decides to hang a big cabinet on that wall.....).
  9. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Be careful, there are many, manyf 2x4 stud, load bearing walls, just about every residential house w/ a basement built before 1980 probably has a load bearing wall right down the middle of the basement, later the steel beams came into favor.
    That being said there are a lot of non-load bearing walls too. But it doesn't matter because you still shouldn't put a 2" pipe through the middle of one even though a lot of people do it.
  10. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
Similar Threads: size pipe
Plumbing Forum, Professional & DIY Advice Sanity check on pipe sizes for new construction Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Can vertical section of waste pipe be reduced in size? Jul 13, 2016
Plumbing Forum, Professional & DIY Advice Water Supply Pipe Size Nov 19, 2015
Plumbing Forum, Professional & DIY Advice New Gas range problem.. pipe size Aug 19, 2015
Plumbing Forum, Professional & DIY Advice Pipe size when adding bathroom? Jul 1, 2015
