what size hot water heater for a spa shower
Discussion in 'Water Heater Forum, Tanks' started by DMC101, Mar 21, 2010.
  1. DMC101
    DMC101 New Member
    Mar 21, 2010
    Richland, WA
    Two people in home. We are installing a Kohler shower system with three water tiles, an overhead, a rainhead, and a hand-held (mostly for cleaning). I have the system set up to turn on each system separately. Based on that, what size gas hot water heater would be optimum for not running out of hot water in our spa shower with all of the valves operating? Thanks. Terry, love this site. Keeps coming up in my research.
    Any suggestions on a brand? I'm getting a good deal on a Kenmore presently, although I haven't researched anything yet. Anything worth checking out at Lowe's or Home Depot?
  2. jadnashua
    You need to determine what's the most of them you'd have running at the same time and how long you would use them. Each should have a gpm value listed for them. Only then can you figure this out.
  4. DMC101
    DMC101 New Member
    Mar 21, 2010
    Richland, WA
    Yes, called Kohler today and I'll let my hubby (the physicist) do the math. Me? That's not my expertise. Thanks
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    You may find this thread useful in figuring out what makes most sense for you.
    It takes a helvua tank to supply high flow rate showers for extended periods of time, but drainwater heat recovery systems can more than double the apparent-capacity of high flow systems (while using less fuel.)
Similar Threads: size water
Water Heater Forum, Tanks Water heater size with and without tempering valve Jul 12, 2014
Water Heater Forum, Tanks New Water Heater: Traditional Vent vs Power Vent, What Brand, What Size Nov 15, 2013
Water Heater Forum, Tanks What size water heater needed for Jacuzzi? Apr 26, 2012
Water Heater Forum, Tanks Hot water recirculation loop size? Jan 18, 2010
Water Heater Forum, Tanks Water Heater Size Jun 12, 2009
