What size for pH neutralizer?
Discussion in 'Water Softener Forum, Questions and Answers' started by Shooter45, Aug 22, 2011.
  1. Shooter45
    Shooter45 New Member
    Mar 9, 2011
    MS
    Can someone help choose which size ph neutralizer I need for our new home with water well? Having a hard time deciding between the 1.5 or 2.0 cu.ft.
    House is 3 bathroom and 4 people. 2 of which are teenage girls who love long showers.
    I tested the well and it produced 5 gal. in 24 seconds which I calculated to be roughly 12.5 gpm? I also ran this "Flow Rate Test for Wells" - http://www.cleanwaterstore.com/technical/water-treatment-calculations/body_flow_rate.html and came up with 8.81 gpm
    ph is - 6.5
    Which would be a good size for us?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    If you have the flow rate then the 2.0 would be a good choice.
    Is there any thing else in the water like iron?
    Which control or valve where you looking to have on the unit?
  4. Shooter45
    Mar 9, 2011
    MS
    Haven't had it tested for iron but I do believe there is some because we do get a thin reddish orange film in toilet bowls.
    Would like the 5600 for the simplicity but have been told that 2.0 works best with the 7000.
    Looking at the flow I posted do you think it is enough for the 2.0?
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    2 cubic calcite would need 7gpm for its back washing.
    The 2510 from fleck would be a better choice over the 7000 valve.
    The 7000 is good but is more for higher flow rates.
    The 5600 has no way of changing any of the parts of the backwash and rinse, while the 2510 the pins can be added to add time to the backwash and spaces added for a slow rinse and pins added for the rapid rinse.
    The 7000 is all digital in its control and more expense if that control goes bad, the 2510 has 2 motors one for the piston and then one for the timer control.. the piston motor is very likely never to go bad while the timer motor could go out it is in the 40.00 range.. digital control for the 7000 would in the 200.00 range.
  6. Shooter45
    Mar 9, 2011
    MS
    would I have a problem running the 1.5 with my flow rate?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    The 1.5 runs lower back wash rate and a lower service flow rate and it might not be enough time for the water to be corrected to above 7.0..
  8. Shooter45
    Mar 9, 2011
    MS
    Thanks. I'll try and find a 2.0 with the 2510 head.
  9. Akpsdvan
    Dec 29, 2009
    Alaska
Similar Threads: size neutralizer
Water Softener Forum, Questions and Answers Gravel type & size Feb 11, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Converting backwash specs to tank size? Feb 5, 2017
Water Softener Forum, Questions and Answers Drain size for kdf and carbon back washing filters Feb 5, 2017
Water Softener Forum, Questions and Answers Softener size and unit? Oct 19, 2016
