What sealant for window well?
Discussion in 'Remodel Forum & Blog' started by Macman, Oct 19, 2009.
  1. Macman
    Macman New Member
    Jan 1, 2008
    My brother installed a hinged window well cover earlier this year. Where the cover meets the brick of the house he used clear silicone seal. A couple of weeks ago we discovered that the silicone seal did not adhere well to the brick and has pulled away. Before I attempt to seal this again, I'm wondering if anyone has any specific suggestions for a sealant or caulk that would adhere well to both the plastic window well cover and the brick.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    A masonry type caulk might work well and cleaning the surface before application of any caulk is the most important thing you can do...it must be bone dry when applied also...
  4. Macman
    Macman New Member
    Jan 1, 2008
    Thanks for the reply Cass. Apparently the masonry caulks are made of polyurethane, which is a pretty aggressive sealant. If anything can stick to both the brick and the plastic, that would be it.
Similar Threads: sealant window
Remodel Forum & Blog tape for foam and sealant for plastic sheeting Mar 4, 2012
Remodel Forum & Blog Silicone Base Waterproofing Sealant Jun 14, 2011
Remodel Forum & Blog masonry sealant Sep 28, 2010
Remodel Forum & Blog Window replacement plus house settling Nov 20, 2016
Remodel Forum & Blog Egress window versus larger window Oct 11, 2016
