What order: Wonderboard, tile, flange
Discussion in 'Toilet Forum discussions' started by idloveaguinness, Jun 28, 2005.
  1. idloveaguinness
    idloveaguinness New Member
    Jun 28, 2005
    Hi -
    Glad I found this place....
    OK - here's the setup. Pro's got me all the way to 5/8" plywood with a lead pipe (3"?) sticking out of a 4" (or so) hole in the plywood that I need to connect to a flange. I've got about 16" of the lead pipe to work with. Now my questions:
    Is the correct order of events: Mortar, 1/2" wonderboard, flange, tile?
    Does the flange "lip" rest on the plywood or wonderboard? Do the flange and tile ultimately need to be flush with each other?
    How do I connect the lead pipe to a flange? Is there a special flange I should use?
    Thanks for any comments....since I'm working with a clean slate, I wanted to get it right the first time.
    edit: If anyone has seen a cross-section diagram, that would be very helpful.
  2. jadnashua
    When you have the option, a correctly installed toilet flange sits on TOP of the finished flooring. To make things easier, notch the tile so you don't have to drill holes through the tile.
  4. remodelingit
    remodelingit New Member
    May 21, 2005
    Everything you could ever need to know about tiling can be found at the John Bridge tiling forum. His "Liberry" has some good stuff on the basics in it. Plenty of pros are willing to provide advice.
  5. idloveaguinness
    Jun 28, 2005
    Thanks for the info fellas.
Similar Threads: order Wonderboard
Toilet Forum discussions Ordering a Toto from a big box store? Mar 8, 2016
Toilet Forum discussions Ordered a Toto Eco Drake Mar 21, 2015
Toilet Forum discussions Ordering Toto Online? Mar 17, 2015
Toilet Forum discussions Proper flange bolt/washer/nut order? Dec 3, 2014
Toilet Forum discussions Mail Order Bride...I mean Toilet Oct 6, 2014
