What Material for Sleeve Through Brick?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by homewrecker, Jan 20, 2007.
  1. homewrecker
    homewrecker New Member
    Jan 2, 2007
    I need to run copper water supply pipes through a brick wall that is 10" thick. I want to bore a large enough hole to allow for a sleeve/conduit through which the copper pipe will run. What should this sleeve be made of? The next size copper pipe, or something harder, like iron pipe?
    Seems like a copper sleeve could be warped if the surrounding brick cracked or moved. If I used iron, wouldn't I need an insulator between the dissimilar metals?
    Thanks for your help!
  2. hj
    pipe
    If the wall moves enough to warp a piece of copper pipe, you have a bigger problem than what to use for a sleeve. PVC or ABS would give the protection without damaging the copper.
  4. santanaf
    santanaf New Member
    Oct 8, 2006
    Mortar is acidic
    If you are going to be doing anything with mortar to fill the hole after the pipe is run, realize that it is somewhat acidic and can corode the copper running through. Even using something like a thick cardboard cylinder (like a thick TP role almost) will protect the copper, but PVC or ABS within a rigid paper tube would be great.
  5. homewrecker
    Jan 2, 2007
    PVC was my first thought, but I wasn't sure if it was rugged enough. Thanks to you both for your advice!
  6. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Might want to consider buying some 10mil tape and putting a couple or three layers on the pipe - that should be sufficient...
Similar Threads: Material Sleeve
Plumbing Forum, Professional & DIY Advice PEX Piping Material Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Proper material for outdoor risers and manifold Feb 3, 2017
Plumbing Forum, Professional & DIY Advice What is this material? Feb 23, 2015
Plumbing Forum, Professional & DIY Advice Looking for advice on best material for shower P trap Apr 28, 2014
