What kind of valve do I have to buy for under the kitchen sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amateurplumber1, Mar 20, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    I think it's the hot water side. I guess I have to turn off the water, cut the pipe underneath the connector, put on the valve, then turn the water back on. Any steps to take before or after turning off the houses water?
    What kind of valve should I buy, exactly? I wanna get a sharkbite version because soldering underneath there would be tough (and I dont have a lot of experience soldering). Here are some pics; i have no idea what the little black wire/thing is, but the hose that attaches to the faucet is off (you can see the hole in the top). Its old as heck.
    Thanks a ton!
  2. Terry
    Aug 17, 2004
    You have a double shutoff there. The tubing to the right is for the dishwasher. You may want to pick up a compression double stop with two handles. That way you don't shut off both the dishwasher and the kitchen sink while when is being repaired.
    I don't know why you would sharkbite something so simple. You just slide on a new shutoff and snug it up with a cresent wrench.
    Are we forgetting how to use tools?
  4. amateurplumber1
    Mar 10, 2013
    Here
    I appreciate the info! Btw, thanks for the forums, I have learned a lot here!
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Instead of a Sharkbite, you should use a compression fitting. You place the nut on the pipe, follow with the compression ring then slip the valve over the pipe end. Screw the nut onto the valve which pushes the ring into place. Tighten the nut with a wrench. Done. These are preferred to sweat fittings because they don't require heat in a tough position and their simplicity makes them very easy to install, or remove and replace if necessary.
  6. amateurplumber1
    Mar 10, 2013
    Here
    Guys, I did it! Thanks a lot for the help! Took your advice and used the compression fitting. Went smoothly. I should probably replace the other valve too. I'm going to replace all the stuff down there. Anyway, thanks again for the advice!
Similar Threads: kind valve
Plumbing Forum, Professional & DIY Advice What kind of valve is this? Apr 17, 2015
Plumbing Forum, Professional & DIY Advice what kind of valve Jul 27, 2009
Plumbing Forum, Professional & DIY Advice What kind of backwater valve to use ? Feb 21, 2008
Plumbing Forum, Professional & DIY Advice What kind of slip washer? Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Taco On Command hot water recirc pump installation gone kind of wrong... Jul 26, 2015
