What kind of tubing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Barry J, Apr 19, 2008.
  1. Barry J
    Barry J Member
    Mar 2, 2007
    Mass
    My outside hose outlet is not located in a very good place, everytime I go to water the back grass, I have to lay the hose over the walkway. I would like to find another way. At first i was thinking of digging under the walkway and laying some maybe "inground sprinkler" pipe in the ground and running it to my deck which is around my pool. That deck is about 75 ft away. Then come up with a pipe and add a spigot by the deck. But that seemed too invovled.
    My other idea was to run either regular hose, toward the left of the hose spigot from the house, I would have to run it below my back door and over the cement steps, then probably over the bulkhead, and then put a hose reel at the corner of the house, that would avoid the walkway.
    Would mounted a regular hose with pipe brackets work better, or should I use, "in-ground piping" for that??
    Or should I just run regular plumbing, to a spigot from my water supply and make another hose outlet on the other side of the door and bulkhead???
    Only problem is, the plumbing would have to run through a non-heated crawl space.
    Any suggestions??
    Barry
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    If you were to put a valve in the line just before it enters the crawl space, you could close that valve and open the outside spigot to drain that line during cold weather. Just be sure to have a little slope down to the outside spigot.
  4. hj
    hose
    The tubing you are planning to use underground is not designed for the usage or pressures involved and will have continual breakage problems. Either use "real" plumbing pipe, or the hose above ground. But it appears you will also have the situation that you have to provide for draining it during the winter. We cannot help with that because we do not know your situation or how it can be accomplished.
  5. Barry J
    Barry J Member
    Mar 2, 2007
    Mass
    Great points. For the underground i figured blow it out with me compressor, but probably too long of a run.
    It looks like either mounting the hose up over the cement stairs and bulkhead (attached to the house)
    Or
    Run a pipe at an angle thru the crawlspace as you mentioned.
    Thanks
    Barry
Similar Threads: kind tubing
Plumbing Forum, Professional & DIY Advice What kind of fitting for this tubing? (fun plumbing photos attached!) Aug 25, 2012
Plumbing Forum, Professional & DIY Advice What kind of water line plan is mine Today at 12:19 PM
Plumbing Forum, Professional & DIY Advice What kind of slip washer? Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Taco On Command hot water recirc pump installation gone kind of wrong... Jul 26, 2015
Plumbing Forum, Professional & DIY Advice What kind of valve is this? Apr 17, 2015
