What kind of maintenance has to be done on a rainsoft softening system?
Discussion in 'Water Softener Forum, Questions and Answers' started by mrginas, Mar 15, 2013.
  1. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
    I have a used rainsoft softening system .it has been disconnected for about two years. Before that it was working fine. Before I hook it up to my new home what would have to be done with it to make sure it's running properly. There are two tanks besides the brine tank . I assume one is a carbon filter tank and the other is a resin tank. Do I have to change any of the resin or carbon,in these tanks? What yearly maintenance is preformed on this equipment ? What is the life span of these systems? How often do you have to change the carbon,resin in this system? I have looked on line for a maintenance manual for this system but I have had no luck in finding one. I have spent many hours on line trying to find this stuff out. Thanks for taking the time to look at this post.
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I found a half dozen or so manuals for various Rainsoft systems after a few minutes' Googling. If you could tell us the exact model number and supply pictures of the overall system and control heads, I'm sure the pros who hang out here could give ou the right scoop.
  4. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
    Hi Mickey
    Sorry it's been so long for a reply to your post.i will be taking pictures of the rainsoft system this week. I also live in cent Florida near Ocala . Do most plumbers in this area know how to seta system like rainsoft up?
    Thank you. Tom
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I can't speak for all plumbers, but I would imagine most would have some knowledge of softeners. RainSoft may be proprietary enough that it can only be serviced fully by authorized RainSoft service facilities. There is a RainSoft dealer locator on the Web; choosing a random Ocala ZIP code for the search, I found Florida Energy Water & Air, Inc., in Archer, but have no experience with them. I do have experience with Los Aviña Mexican Restaurant in Archer, though -- excellent.
    [h=1][/h]
  6. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
    image.jpg image.jpg image.jpg image.jpg Ok so this is what I have. I got this from my daughters house in Charleston sc . It was put in by the former owner. The water in that house was not hard but the owner was sold a bill of goods. My daughter had it un hooked about two years ago when she had a new hot water tank put in. I got it and now and was wondering if it is worth while to have it hooked up. One tank I think is a carbon pre filter but I'm not sure. They have been sitting for two years not hooked up .do I have to change the resin and carbon? Can a new valve be installed on the tank? The system was put in around 2001 in SC , maybe used for about ten years. I don't know if the rain soft tanks are universal, if they are I was thinking of using them and just replacing the timer and valve. This system was working when it was taken out. Hopefully the pictures will come thru.
  7. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
    Sorry for the double pics ,it was a learning curve , lol
  8. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Resin can be tested to see if it is still good. Get a sample and squeese it between thumb and finger. If it smaches up it no good. Carbon is a breeding ground for bacteria. Being unhooked for 2 years is not good. Seeing it is a health issue, I would replace it to be safe. I don't believe the tanks can be used for another valve unles they have an adpator converting a standard tank to fit the Rainsoft valve. Send a closer pic of were the valve mounts to the tank.
  9. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
  10. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    It does not look like they used an adaptor to convert a standard tank. Rainsoft thread and tank opening size are not standard so you will not be able to use another valve on those tanks.
  11. mrginas
    mrginas New Member
    Feb 21, 2013
    fl
    That's what I thought ,and thanks for your response .
Similar Threads: kind maintenance
Water Softener Forum, Questions and Answers Mix different kinds of salt in the water softener Mar 27, 2014
Water Softener Forum, Questions and Answers Regular Maintenance for Fleck 5600SXT? Jun 26, 2016
Water Softener Forum, Questions and Answers Softener maintenance questions. Jun 30, 2013
Water Softener Forum, Questions and Answers Fleck 2500 control valve and help with softener maintenance Aug 18, 2012
Water Softener Forum, Questions and Answers routine maintenance, is cleaning of softener resin advisable? Jul 1, 2012
