Hi fellas,
A pipe running from my tub was leaking so I went to take a look at the culprit, and found 1 and 1/2 inch threaded metal pipe feeding into a 2" cast iron vertical stack:
This is the pipe after I pulled it out:
http://imgur.com/K40Hqm0
http://imgur.com/8YUELtn
... and here is where it was connected to to the stack (the threaded 45 degree fitting there connects to another metal nipple that connects to the threaded hub in the stack):
http://imgur.com/9dWZ0l0
The plumbing elsewhere in the house is PVC connected to cast iron vertical stacks, so I'd like to do the same thing here. What is the best way to transition from that metal threaded hub to PVC?
Thanks for your help!
