What kind of Copper to CPVC fitting is this?
JerryR
Active Member
Florida
I have good amount of experience sweating copper. I also have done a lot of PVC work with my irrigation system. I have no experience with mating copper to CPVC. I've replace several water heaters using copper only. Our vacation home has CPVC connected to the heater which I will be replacing shortly.
Looking at the pictures you can see the adaptor is sweated onto the ¾†copper not very far from the wall. I do not want to put a torch to this as it is too close to the interior garage wallboard. Not being familiar with this adaptor I have several questions?
• Can someone tell me how the CPVC attached to this fitting?
• Is it threaded?
• Can it be reused?
• Is the CPVC 90d a special 90 to connect to the adaptor?
I will be replacing the WH and before cutting out the CPVC I want to make sure I have what I need to complete the job.
Jerry
JerryR
Active Member
Florida
It appears to be a copper to PVC transition union, which should unscrew.
So is it similar to one of these? I then should put an open end wrench on the flat to prevent the 3/4?†copper from rotating and rotate the knurled ring counter clockwise with a pipe wrench?
Jerry
Cacher_Chick
Test, Don't Guess!
Using a pipe wrench could distort the knurled fitting.
I would give it all I had with my hand first (a glove might help).
If I had to use a tool, my first choice would be a strap wrench.
