What is this extra pipe?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by rburt5, Jun 12, 2006.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I recently repaired a leak in the underground pipe that leads to my bladder tank. When I dug down to it, I noticed that there are actually two pipes going from my well pump into my house. One goes to the bladder tank. The other goes into my basement through the foundation, but it is not connected to anything and it is not capped off. Should I remove the pipe that does not connect to anything, or is it needed for air flow?.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It is either a pipe leading to an outside yard hydrant or similar or it's an old well line that developed a leak and rather than find and fix it they just replaced the line a abandoned the old one in place.
    Thats my guess. Most likely and old line. It is definately not for air.
  4. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    Extra pipe
    I agree that it looks more like an old line that was replaced. Should I cap it off and remove it? If so, should I cap it off right at the vertical pipe that goes down to the well (and remove the old pipe), or should I leave it how it is?
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The pipe isn't really causing any problem, so why not just cut it off as much as possible and seal it up with a tube of silicone caulk in both ends.
  6. vaplumber
    vaplumber Guest
    >>>Sounds like somebody has replaced your well line in the past, and abandoned the old line. We do this all the time, as it is much cheaper and easier than finding and repairing the leak. Cap it off or plug it where it comes through your foundation wall to keep rodents from using it, and ignore it.
Similar Threads: extra pipe
Pumps and Tanks Well Forum & Blog Extraction of submersible pump Apr 4, 2011
Pumps and Tanks Well Forum & Blog Need help with pump extraction Jul 23, 2008
Pumps and Tanks Well Forum & Blog how can i add extra pressure for distance on a well? Nov 19, 2007
Pumps and Tanks Well Forum & Blog Do extra fittings cause loss of flow or pressure? May 23, 2007
Pumps and Tanks Well Forum & Blog Water/sediment leaking from well head vent pipe. Wednesday at 12:19 PM
