What is the shortcut in siphon (CST744EL)
Discussion in 'Toilet Forum discussions' started by Plumber'sSon, Jul 17, 2014.
  1. Plumber'sSon
    Plumber'sSon New Member
    Jul 14, 2014
    Hi experts,
    I have not seen this short 'pipe' connecting two siphon branches anywhere else.
    What is it for?
    Thanks
    [​IMG]
  2. Terry
    Aug 17, 2004
    It's not a shortcut, but more likely the way they cast the bowl.
  4. Plumber'sSon
    Jul 14, 2014
    Oops, I think the picture just changed. Probably I sent the link rather than the picture.
    Trying again (the real one)
    [​IMG]
  5. Terry
    Aug 17, 2004
    It's still not a shortcut.
    And that will be $1.00 for posting the ad.
  6. Plumber'sSon
    Jul 14, 2014
    Sorry Terry,
    I did not know I violated some rules.
    This was the only picture I found that showed my toilet with this short 'pipe'.
    What is your opinion on Danco Perfect Seal?
    My flange is not level. It is about 1 / 8 '' (or little bit more) below the tiles on the back and about 1 / 8 '' (or little bit more) above the tiles on front. The toilet I am replacing had a leak, so I am wondering what kind of seal should I use now to be safe.
    Thanks
  7. jadnashua
    A wax seal, maybe a jumbo, should work fine. Keep in mind, though, that ANY rocking of the toilet after it is set will likely break the wax seal - you MUST shim the toilet so it doesn't rock when you set it onto the wax. The wax is NOT springy, and if it rocks one way, compressing the wax, when it rocks back the other, you'll now have a gap that can leak. WHen you set the toilet, you should be able to feel the wax being compressed...if you don't, you may need a thicker wax ring or to fix the flange's position.
  8. Terry
    Aug 17, 2004
    Here are some pictures from American Standard bowls.
    [​IMG]
    American Standard Plebe
    [​IMG]
  9. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    A look into the bowl of any of these confirms that there is no opening where these tubes connect at the beginning of the trapway. Could they be there for structural support of the wet clay while it's being fired?
Similar Threads: shortcut siphon
Toilet Forum discussions Euro siphonic toilet Apr 10, 2015
Toilet Forum discussions Eljer Toilet Without Siphon Jet Dec 7, 2014
Toilet Forum discussions New toilet is siphoning my sink Oct 20, 2014
Toilet Forum discussions Old Kohler Wellworth with plastic tubing for siphon jet Sep 7, 2014
Toilet Forum discussions Suggestions on cleaning toilet siphon jet opening Mar 6, 2014
